Lusso V12 feels slow in city streets...... | FerrariChat
Discussion in 'FF/Lusso' started by bruno787, Apr 10, 2019.
  1. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    ived noticed on several random occasions that my car when driving just around 30-40kmh on city streets when floored to overtake slower cars do not react as expected. it feels as if it takes the car a second or two to react.
  2. ttforcefed
    ttforcefed F1 World Champ
    18,870
    Ff does same thing and if you floor it completely it downshifts to an incredible low gear and then reacts
  3. NeilF8888
    NeilF8888 Formula 3
    Feb 10, 2005
    1,147
    Miami Beach
    Don’t be lazy and pull the left paddle a couple of times (downshift) while flooring it.
    italiafan, Bas, Nelsonc275 and 3 others like this.
  4. FFantastic
    FFantastic Formula Junior
    Mar 23, 2015
    857
    UK Riviera
    It's a finely tuned instrument that need playing not just using. I had about ten guitars when I was young....................none of them worked yet Hank Marvin bought one and it worked straight away.....funny that?
    crinoid, 635CSI and R J like this.
  5. stavura
    stavura Formula 3
    Sep 1, 2016
    1,328
    U.K
    Harold Lounge
    I think the problem is that your driving at 30-40kmh ;)
    LightGuy likes this.
  6. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    sometimes overtaking at 60kmh, the car cant seem to downshift fast enough :(
  7. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,662
    Bournemouth, UK
    It amazes me that people drive a Ferrari in Auto mode...
    FFantastic, deltona, klinkman and 2 others like this.
  8. Sonicsound
    Sonicsound Karting
    May 14, 2017
    125
    What’s that?
    REALZEUS likes this.
  9. ttforcefed
    18,870
    Thats pretty funny. Squeezing a paddle makes it what? Manly? Its still automatic. Auto in FF is as good as anything else.
    otakki likes this.
  10. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    otakki and ryalex like this.
  11. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    N/A engine, the higher torque comes only at higher revs so the car driven in a city at low speeds, high gear (3rd or 4th at 30mph )will not react as quickly as turbocharged one like a Conti GT or any AMG.
    Using paddles, you can keep the gears lower then Auto would and have the reaction from the engine immediately.
  12. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,662
    Bournemouth, UK
    No, it's not. It's a dual clutch semi-automatic transmission, primarily designed for manual operation. The auto function is just an added feature.
    350MH83 and Kuba like this.
  13. 635CSI
    635CSI F1 Rookie
    Jun 26, 2013
    3,001
    London UK
    Graham
    Or indeed our own Lusso V8TT ;)
    Seriously though I agree with the above comments that its more likely the gear box in auto mode being in too higher gear, maybe it would be less likely to be so in "sport" with "bumpy road" engaged for ride comfort?
    If not just pull the paddle marked "down" and it will drop a gear even in auto, or better still just drive in "manual".
  14. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    7,734
    Tropical
    Is that Manila? Good luck dodging the Jeepneyso_O
  15. ttforcefed
    18,870
    If u arent stepping on a clutch, its automatic
  16. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    actually 97% of jeepneys give way to a ferrari :) its the president's city
  17. Ferrari 308 GTB
    Feb 21, 2015
    7,734
    Tropical
  18. 635CSI
    635CSI F1 Rookie
    Jun 26, 2013
    3,001
    London UK
    Graham
    Can see your point but I think if it has cogs in the gear box and not a torque converter, it’s a manual
    350MH83 and REALZEUS like this.
  19. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,662
    Bournemouth, UK
    So the sequential racing boxes are automatics? :rolleyes:
  20. ttforcefed
    18,870
    there is zero difference between 100 percent throttle in auto and 100 percent throttle using your hand - so why use ur hand?
    and oh it sounds better in auto downshifting, bigtime
  21. vraa
    vraa F1 Rookie
    3,571
    Texas
    Mr. A
    I can't seem to kick down gears I want fast enough
    @ttfor
  22. vraa
    vraa F1 Rookie
    3,571
    Texas
    Mr. A
    @ttforcefed are you double or triple clicking the paddles? I find that's much faster than auto for sensing what gear I wanna be in to over take and get into rev range
    Drew_1 likes this.
  23. lamborarri
    lamborarri Formula Junior
    Nov 15, 2015
    452
    Yes it does feel slower than other ferraris when its in traffic probably due to its long gears and power band. if you want it stays within the instant power, drive it in manual so you can keep the rev around 2500-3000 rpm.
  24. ttforcefed
    18,870
    My comment was referring to starting from a stand still.
    crinoid likes this.
  25. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,662
    Bournemouth, UK
    i. Because you can upshift when you want to.
    ii. The manual downshift blips are just about the same.
