M-Tecnologia Front Spoiler for F355 | Page 2 | FerrariChat
Discussion in '348/355' started by corsa1997, Apr 21, 2009.
  1. Billdemart
    Billdemart Karting
    Mar 30, 2009
    92
    Atlanta, GA
    Billy D
  2. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #27 corsa1997, Apr 24, 2009
    Maybe about 50mm lowered and spring brand is HYPERCO.
  3. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Zero:
    If you like that grill, Gothspeed's version is quite similar and he will paint/powdercoat it to your color specification. Be aware though, that there are a series of vertical panels (structural members) that are highly visible through mesh-type grills. Perhaps a tighter/smaller mesh size would mitigate this effect. Oz?????
  4. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #29 corsa1997, Apr 24, 2009
  5. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    That grille is from the www.Tubistylejapan.com they sell them but I can't get incontact with them anyone from Japan knows how please let mes know.
  6. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    The grille sold by Tubi is made by M-Tecnologia,and Rhdjapan is an export agency of M-tecnologia.
    Coming in contact with Rhdjapan is good.
    http://www.rhdjapan.net/index.html
  7. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Very impressive set-up!!! Dual spring Hyperco's with fluid spring perch...WOW!! You can use a rubber tube to seal the hydralic spring seat and it will last a looooong time.
    Who made the pin-mount to top hat mono-ball conversion???????????
    Having gone to that much expense why did you go with those crappy CH Bilstein dampers?? They may have been regulated for CH races but since you have totally deregulated the suspension a set of Penske 3ways would have been the "bomb"....probably cheaper too.
  8. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    That's not the way a splitter/front diffuser works. No opening is needed, and can actually be detrimental. The splitter portion is what sticks out ahead of the bumper, and creates downforce by tapping into the high pressure zone ahead of the blunt bumper. The diffuser part is what extends back past the front edge of the bumper, and accelerates the air going to the underbody, lowering the pressure under the nose and produces negative lift.
    This pieces looks nice, but not on the car IMO. Looks high quality, and worth the cost if it's well made. A more "functional" front spoiler could be made, but would look like a race car piece instead.
  9. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #34 corsa1997, Apr 29, 2009
    Thanks! Rubber tube is good idea.
    It was converted with Bilstein Technical Center.
    I wanted to confirm the difference in spring.
    Penske is good but that is more interesting.
  10. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Thanks Ken for taking the time to post the mods made to your car....you have done an excellent job on individualizing this 355.
    That shock set-up is the BEST I've seen in incorporating the CH Bilstein dampers..truly a work of art.
    My only regret is that the 348GTC/LM upper chassis mounts are not available.....and to machine these up along with the pin mount to mono-ball top hats is beyond my pocket book.
    If you get a chance please post pics of the interior, engine, and whatever else will show off the best mods you've done.
    Regards
    Bruce
  11. vittorio
    vittorio Karting
    Nov 12, 2003
    203
    Italy
    vittorio
    #36 vittorio, May 2, 2009
  12. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    I think so,and told it to Hyperco Japan.
  13. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #38 corsa1997, May 3, 2009
    Thanks Bruce!
    Dry Carbon Hood
  14. vittorio
    vittorio Karting
    Nov 12, 2003
    203
    Italy
    vittorio
    That's so cool!
    Who produce it?
  15. vittorio
    vittorio Karting
    Nov 12, 2003
    203
    Italy
    vittorio
    M-Tecnologia ?
  16. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
  17. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,107
    ESP
    Bas
    Corsa1997, you have the most awesome 355 i've ever seen! Very nice mods on it:).
    Anyone thinking of ordering this via RHDJapan, they can get their hands on a lot of stuff and it gets delivered VERY quick. Great service (worldwide).
  18. TopElement
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    So these are made with pre-preg and autoclaved cured? They look nice, but I'm not quite sold on the quality of engineering behind the products. But they're the only choice...
  19. vittorio
    vittorio Karting
    Nov 12, 2003
    203
    Italy
    vittorio
  20. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #45 corsa1997, May 3, 2009
    Yes,pre-preg and autoclaved.
    Weight;
    Nomal food; 12kg
    Dry carbon food; 4kg
    Thanks!
  21. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    OK!!!! I'm moving to Japan....lol
  22. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #47 corsa1997, May 4, 2009
    Bruce,Come on!!!
  23. corsa1997
    corsa1997 Rookie
    Oct 29, 2005
    31
    #48 corsa1997, Jun 8, 2009
  24. gatorgreg
    gatorgreg Formula 3
    1,951
    NAPLES
    Greg Griffin
    Thanks for sharing. What a setup!!!!!!!!
  25. Night life
    Night life F1 Veteran
    7,320
    The city that rhymes with fun in Canada
    Roberto
    Late to the party as usual but that if friggin awesome looking totally changes the look of the front end more aggressive the way it should of been from the beginning.
