MAC guys...I need some help. | FerrariChat
Discussion in 'Other Off Topic Forum' started by Motoracer, May 16, 2006.
  1. Motoracer
    Motoracer Karting
    May 23, 2004
    89
    Wayne NJ
    Kyle
    Can anyone tell me how to make my safari page larger? I don't know what I hit, but it is pretty small right now, only taking up about 3/4 of the screen. I try to hit the maximize button, but that doesn't do anything.
    Anyone know how to make it larger?
    Thanks.
    -Kyle
  2. bonedoc
    bonedoc Karting
    Jul 31, 2004
    212
    If you want to make the window larger, click and drag the lower right corner. If you want to make the text larger, push the button with the apple and the "+' key at the same time.
    If you are really bored, open the app called script editor, type this in, and hit play.
    tell application "System Events" to tell process "Safari"
    set x to 1000
    set y to 650
    set size of window 1 to {x, y}
    end tell
  3. TigerAce
    TigerAce Formula 3
    May 29, 2003
    1,793
    Dallas, TX
    Yoshi Ace
    I only knew the first 2 method you suggested. I didn't even know "System Events". There are much more I need to learn.
    Motoracer,
    Hope you solved your problem. I never had your problem, and can't even guess what you hit to let this happen. Kinda curious how this happened.
