Made my own Stainless CV boot heat shields | FerrariChat
Discussion in '348/355' started by treedee3d, Apr 4, 2021.
  1. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    The original Ferrari ones keep burning out and they’re costly. Also, my setup is fully catless with Fabspeed headers and I do not have a challenge grille so it gets pretty hot in there and my motor mounts and cv boots burn out every year if it wasn’t for the heat shields.
    Up to now I was using the original Ferrari ones with extra heat shield reflective paper and that method performed well but looks darn ugly when you open the hood.
    I looked for alternatives but could not find any other than the Goth shields on Ricambi that looked damn good and well built but the product says “unavailable” unfortunately. I also saw some carbon fibre ones on Superformance but I just don’t see Carbon Fibre as being an effective heat shield material...
    So I got a piece of 16 gauge stainless steel, traced the stock ones, cut them out with a grinder and made the 2 holes then bent them. I also decided to get the ceramic coating done and there you have it!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. FourthAlfa
    FourthAlfa Karting
    184
    Paris, France
    Andrew Love
    Nice job!
    jimmym and treedee3d like this.
  3. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    Nice fabrication.
    Half the problem it looks like you have is the y pipe touching the heatshields. On the 2.7 there is not much room at all between the y pipe and the axle heat shields. I carefully adjusted my mounts so there is more room to clear the y pipe and also taking care not to bring the shields too close to the cv boots. No more issues and they hold up well.
    Something to look for as being metal if these touch it will rattle as opposed to wear away like the fiberglass.
  4. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Yes indeed that is the case, a 2.7 an very little room. I will try to adjust and bend to see how they perform and check for rattling.
  5. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    Bend the bracket down there can be plenty of room. Until I did that I was always rubbing.
    treedee3d likes this.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Willl, treedee3d and jimmym like this.
  7. Ricambi America
    Sponsor Owner
    willrace and treedee3d like this.
  8. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    That's to keep the beer cold, Daniel. They don't have refrigerators up there is the cold north. :D
  9. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    It is indeed kinda depressing.... but as of today it's almost all melted thank God!
  10. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    These aren't going to be much more effective than the factory shields. The factory shields only protect the tops of the boots from the Y-pipe, leaving the boots unshielded from the heat coming from the lower primary exhaust pipe. The advantage of the Goth shields wasn't that they were made out of stainless, it was that they wrapped down around the axle and shielded the boot from *both* pipes. I tried to find Goth shields and couldn't, and fabbed similar ones out of thin galvanized sheet metal and covered it with modern heat shielding. Doesn't look as pretty but my boots will probably last a long time.
    This video (not mine obviously) shows pretty well how the factory shields only address part of the problem.
  11. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    There was a very interesting/informative article on Chat from someone who was very familiar with thermal dynamic. I couldn't find the link. Was a good read on how to protect parts from heat degradation. Do a search you might have better luck than me.
  12. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Your post makes a lot of sense and those shields look really awesome. I probably could have spent a little more time and made identical ones but was in a bit of a rush. Not sure why they’re no longer available? Looks like a great effective product indeed.
    Until I doubled/lined the stock ones with some heat shield material I kept having to change the boots every year. I’m hoping these Stainless ones will work but probably could have done better.
    I’ll keep the thread updated as time/mileage goes on and we’ll see I guess.
    Targatime likes this.
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    You can really easily add material to your shields that wraps down on both sides of the axle. Could use rivets or short fasteners. Then cover the whole thing with adhesive-backed shielding from DEI so it looks good. Do it!
  14. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    Here, dug up a couple of pics. I built an additional shield that sits on top of the factory shield. They're a little crude but the upside is I'm pretty sure I'm not going to have to change out my CV boots anytime soon. They were last changed during the major the PO did on my car a few hundred miles before I bought it and you can see in the second pic the old caked on grease around the CV joint from multiple past boot failures. Second pic is a side view with the shield installed that shows how far down it extends to protect the boot.
  15. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    that looks awesome!
  16. darrenliu
    darrenliu Formula Junior
    Jun 24, 2008
    450
    Melbourne Australia
    Darren Liu
    Has anyone got a pair of goth shield or similar for sale? Im tired of replacing my CV boots every few years.
  17. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    925
    Europa
    Bob
    I was getting through CV boots alarmingly fast, always right hand side, left side seemed to last indefinitely. Anyway, messed about with various heat shield solutions but in the end, the single best thing I did was to wrap the exhaust in that area with heat shield wrap. Never had another CV boot go since and that was over 10 years ago.
    there are tons of options of wrap (I don’t remember what brand I used, got it from a local race shop) anyway, here’s an example:
    https://www.amazon.com/Design-Engineering-010131-Titanium-Technology/dp/B0039Z1UHA/ref=m_pd_aw_vtp_sccl_4/133-5508199-8998444?pd_rd_w=4L1qQ&content-id=amzn1.sym.b8794477-21f6-4384-8a41-3f4639665fd0&pf_rd_p=b8794477-21f6-4384-8a41-3f4639665fd0&pf_rd_r=16R4XGN1B4JGGTQ8G3EP&pd_rd_wg=acm5u&pd_rd_r=09d251b8-11a5-4bed-a7b4-cee5314ac56f&pd_rd_i=B0039Z1UHA&psc=1
  18. ssnowball
    ssnowball Formula Junior
    295
    Scot
    Goth was mentioned in a recent post, perhaps he has an additional pair? Love mine, been in place for years.
  19. darrenliu
    Jun 24, 2008
    450
    Melbourne Australia
    Darren Liu
    yes, exactly the same with mine, always the right hand side. Thank you for the tip! How much of the exhaust do you wrap? Do you wrap the cat or just the pipe before it gets to the cat?
  20. darrenliu
    Jun 24, 2008
    450
    Melbourne Australia
    Darren Liu
    Is he still around? i cant seem to find him.
  21. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
    My theory on the reason for the right hand boot getting cooked is that the RH side is more “congested” than the left side with the alternator and oil tank restricting the airflow making it generally hotter. LH side is more “open” and gets better airflow — just a theory.
    But anyway, to answer your question, I have wrapped the area from approx 10cm ahead of the driveshaft up to and including the catalyst flanges. I used the stainless steel zip ties just after the flanges to get the wrap good & tight. I didn’t wrap the catalysts. As I say, I got >10 years out of the last set of boots compared to one summer of hard driving “un-wrapped”.
    I just recently changed the boots “while I was in there” but they didn’t really need it.
  22. salbrech
    salbrech Karting
    Dec 20, 2013
    107
    Hi,
    I also did something similar on my 5.2:
    - I added fiberglass enforced aluminum insulation sheet onto the original covers
    - I added insulation on the main cat inlet flange
    (I know on the picture the CV boot is damaged - it was already before the modification)
    Best regards
  23. darrenliu
    Jun 24, 2008
    450
    Melbourne Australia
    Darren Liu
    Thanks Guys (Spaghetti and Salbrech) for your posts, im going to add some wrapping to try and stop my CV boots from melting. Appreciate the help guys.
    spaghetti_jet and salbrech like this.
  24. magnum69
    magnum69 Rookie
    Dec 4, 2015
    25
    Arizona
    Richard Gozinya
    Had to chime in on this one and share my experience,
    Standard headers still good and had to replace motor mounts and CV. Found an aftermarket custom header set on Eurospares in UK and decided to have it sprayed zircotec performance white on its way back to the US for the header swap out.
    Sent the downstream components minus the Tubi to Swaintech in NY for their white lightning coating. Both hit with black high temp paint before install. Both very durable with the Swaintech thick and rough on the surface. Not like paint but more like molten ceramic shot through a plasma gun:
    Very noticeable difference to the temps in the engine compartment especially after shutdown.
    I also picked up some self adhesive zircoflex and crudely covered some of the vulnerable parts for extra insurance with the scraps from my covering another heat shield in the product. It has lasted very well with no component failures. Research it as they have added new products and wraps. Very high heat reflection rates.
    https://zircotec.com/products/heat-shields/zircoflex-shield/
    aircraft spruce sells zircoflex sheets in the US.
    both Swaintech and Zircotec companies very nice to work with and professional. Zircotec is in most F1 cars and industrial applications as well.
    for this OPs application, a self adhesive Zircoflex in the desired locations should shield the components. Added to a heat shield and it would be very good protection. They advertise 65-85% thermal reduction depending on which zircotec foil you use.
  25. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    955
    @ssnowball and all others would have Goth shields:
    Anyone willing to take some comprehensive measurements?
    Will use 16 ga stainless like treedee3d unless someone has a better idea?
