MAF in 2.7 Motoronic F355 | FerrariChat
Discussion in '348/355' started by Rorie, Oct 10, 2020.
  1. Rorie
    Rorie Formula Junior
    Oct 2, 2007
    459
    Toronto, Canada
    Going to clean the MAF's tomorrow. Does anyone have pics of what to clean?
    I read the posts. I am more of a visual learner.
    Cleaning Airfilters as well.
    Getting issues with a bit of a rough idle when hot, and also now a CEL 1-4 light is on and stays on.
    Thanks in advance.
    Rorie
  2. Qavion
    Qavion F1 World Champ
    14,283
    Ian Riddell
    #2 Qavion, Oct 10, 2020
    There is nothing special about the 355 MAF. Just follow the instructions in YouTube videos...
    i.e.
    disconnect the plug
    remove the MAF from the car completely (2 clamps... & maybe the airbox?)
    10~15 bursts of specific MAF cleaner (nothing else), some say two fairly long bursts with drying time between.
    don't touch the internal components with anything but the cleaner
    let dry for 10~15 minutes (some videos say an hour)
    The engine management system may need to recalibrate itself after this before it runs normally. There should be posts on the forum on how to do an ECU reset.
    Here is Forum guru Ernie's post on this:
    https://www.ferrarichat.com/forum/posts/139678976/
    Thanks for telling us what car you have :) The 1~4 Check Engine Light tells you it could be the MAF on the right hand side of the engine (standing at the back of the car, looking forward) causing the problem.
    Because you have a 2.7 car, there is a special procedure for extracting the fault codes from the Motronic (engine) ECUs
    GatedF355GTB and 308 GTB like this.
  3. Qavion
    14,283
    Ian Riddell
    P.S. It won't hurt to clean the pins/socket on the MAF electrical plug, also. Any cleaner such as isoprolyl alcohol will do, as long as it doesn't leave a residue. I guess MAF cleaner would do the job, too.
    If you clean both MAF sensors at the same time, it might also be a good idea to swap them as part of faultfinding. If no luck with swapping and cleaning, we'll take you through the fault code reading process or we can move onto ignition and other things.
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
