Magnetic Oil Drain Plug for Ferrari 308 Engine - Feasibility and Thoughts? | FerrariChat
Discussion in '308/328' started by ItalianProjects101, Oct 22, 2024.
  1. ItalianProjects101
    Feb 5, 2023
    215
    D
    Hi everyone,
    I was wondering if anyone has experience or knowledge about installing a magnetic oil drain plug for the engine oil in a wet sump Ferrari 308? I know that the gearbox casing has a magnetic drain plug, and from what I understand, the 288 GTO and F40 used to use them for the engine as well.
    It seems like a wise upgrade for the engine oil drain plug, as it would help collect any metal debris and potentially prevent future issues. Does anyone know why the Ferrari 308 didn't come with a magnetic drain plug for the engine oil in the first place? Has anyone here made this modification, and if so, is there any reason not to?
    Looking forward to your thoughts and advice!
    The one I'm referring to is the following:
  2. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    187
    Boerne, TX
    Rodney Bolt
    I don't know what a 308 drain plug looks like, but my '89 328 has an indent on the socket-side (exterior) of the engine oil drain plug that was just begging for a ¼" neodymium magnet. So I put one in. Exact fit. That magnetic is so strong, it's not coming out.
  3. Rifledriver
    36,779
    And what advantage will that provide?
  4. ItalianProjects101
    Feb 5, 2023
    215
    D
    This is the stock drain plug.
    Essentially the same as the gearbox one, just without a magnet.
  5. ItalianProjects101
    Feb 5, 2023
    215
    D
    Collect any magnetic material, espcially now since I still need to run in the engine. i..e from the rings.
  6. Rifledriver
    36,779
    Transmissions generate a lot of ferrous debris and have no filter, hence the magnet. Engines generate almost no ferrous debris and have wonderful filtration systems and have no need for a magnet. Manufacturers of every make of automobile in the world are pretty smart that way.
  7. ItalianProjects101
    Feb 5, 2023
    215
    D
    I understand that, but I don't think it will hurt... or will it? Just helping that little extra. I have a spare one
  8. s219
    s219 Formula Junior
    Aug 26, 2021
    473
    I think you have much bigger problems if a magnet catches metal particles or metallic sludge in the oil pan of an engine that runs an oil filter. It would be a major anomaly for this to occur in normal operation. Gearboxes and differentials are an entirely different story, as Rifledriver explained well.
    waymar likes this.
  9. moysiuan
    moysiuan F1 Rookie
    4,085
    Canada
    Typically available noedimium supermagnets can't handle oil sump temperatures, they will embrittle and fragment, so defeats the purpose.
    If you can get a samarian cobalt magnet that could handle the sump temp. They are available but more costly.
  10. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,597
    California SF bay area
    Paul
    They also lose their magnetism when they get hot. I tried embedding them in a 3D print project with a soldering iron and they didn't work.
  11. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    187
    Boerne, TX
    Rodney Bolt
    I've never seen over 210F oil temp, even driving hard on 100+F days. Nearly 8 months on, my neodymium magnetic bolt is still magnetic and hasn't disintegrated. You can see the magnet disc on the outside of the bolt in the attached pic.
    When I change the oil next spring, I'll report back what I find. Hopefully, nothing.
  12. moysiuan
    moysiuan F1 Rookie
    4,085
    Canada
    Oops, I was thinking the magnet was on the inside of the bolt in the sump like the gearbox plug style when I glanced at this thread. But of course that would not work with the stock oil sump plug.
    I Can't see why what you have done would cause any issue, if the magnet did fail it would just fall off with no harm done.
    The higher temp tolerant cobalt magnets I noted are on Amazon, so they are readily available.
