Main bearing and con rod tightening torques? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 365mat, Nov 5, 2020.
  1. 365mat
    365mat Rookie
    Nov 3, 2020
    5
    Mathew Reader
    Hi,
    Does anyone have the main bearing cap and con rod bolt tightening torque settings for the 365 2+2 V12 engine?
    Thanks.
  2. Tegethoff
    Tegethoff Formula Junior
    Jul 19, 2014
    301
    Los Feliz
    Adam
    Main - 8.25kg ~59 ft lb
    Rod - 5.51kg~ 40 ft lb
  3. Ak Jim
    Ak Jim F1 Veteran
    9,467
    North Pole AK
    Are you talking about a 365 GT4 2+2 because if not they are completely different engines. I’d recommend you get a shop manual instead of asking these questions on the internet. Now if you are just verifying info you already have that’s fine.
    GTM308 likes this.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,307
    Lyon (FR)
    R. Emin
  5. 365mat
    365mat Rookie
    Nov 3, 2020
    5
    Mathew Reader
    I was told 80nm for the main cap nuts so that confirms that, thanks Tegethoff.
    Where would I find a 365 GT 2+2 manual with the engine specs? I am happy to buy one I just can't find it anywhere!
  6. Ak Jim
    Ak Jim F1 Veteran
    9,467
    North Pole AK
    Just trying to help. You say you have a 365 GT 2+2. This section here at Ferrari Chat is about the Ferrari 365 GT4 2+2.
    If your engine has single overhead camshafts and three down draft Weber carbs then the best area to ask about your car is in the Vintage section of Ferrari Chat.
    If your engine has double overhead cams and 6 Weber sidedraft carbs then this is the correct section.
    So do you have 3 Weber downdraft carbs or Six Weber Sidedraft carbs?
    Once we can establish what you have someone can probably help you find a manual.
  7. 365mat
    365mat Rookie
    Nov 3, 2020
    5
    Mathew Reader
    Ahh yes I have posted in the wrong section, it is a GT 2+2 with triple carbs and single cams.
    I have heard of the Angelo Wallace translated manual but not sure it is available for the 365?
  8. raemin
    raemin Formula 3
    Jan 16, 2007
    2,307
    Lyon (FR)
    R. Emin
    This one is for GTC4 (i.e like 400 not like the daytona).
  9. rovexienus
    rovexienus Formula Junior
    587
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
