430 - Maintain Battery | FerrariChat
430 Maintain Battery
Discussion in '360/430' started by aleary360, Feb 18, 2020.
  1. aleary360
    aleary360 Karting
    Nov 23, 2015
    172
    Westlake Village, CA
    Al Leary
    Gentlemen,
    Question for you please. I'm moving to a condo with car port only. The is no power outlet for me to plugin my Battery tender. Any recommendations on how to maintain battery besides maybe start it once a week.
    Is there such thing as a portable charger to plug in my battery tender?
    Thank you!!!
  2. up4speed
    up4speed F1 Rookie
    3,699
    Long Island, NY
    Chris
    Tough scenario. I have no idea if it would work well enough or not, but it's the only thing I can think of off the top of my head.
    - A solar battery maintainer
    https://www.amazon.com/dp/B07TC3GJS4/ref=dp_cerb_3
    I would wire it directly to battery (instead of cigarette lighter), and I would probably mount it to the top of the car port, and run a wire down, in order to maximize sun exposure.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Unless you drive it for at least 30 minutes, starting it once a week will net drain the battery.
  4. CarbonDan
    CarbonDan Karting
    191
    PNW
    Solar battery tender is by a mile the best option. Otherwise, hit the manual cut off switch everytime. They will drain the battery out within a week in most cases (with some variation here of course). But it's really harsh on the alternator to allow it to charge up a depleted battery constantly. Solar tender will be the only viable option.
  5. 9650max
    9650max Karting
    173
    Priority Start 12volt Pro Max
    Available at Walmart or other online sources or some battery stores.
  6. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    I agree that solar charger is his best option. BUT, if your battery only lasts a week you have bigger problems. 2-3 weeks easy but 4 is pushing it a bit (it sags but will still start).
    EastMemphis likes this.
  7. f355spider
    f355spider F1 World Champ
    18,047
    Long extension cord.
    DOWORKFCAR likes this.
  8. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,734
    Just East of Weird
    Bob
    long shot... but ask building management if they can hardwire an electrical line to your parking space (at your expense I'm sure). ya don't ask ya don't get.
  9. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    f355spider likes this.
  10. f355spider
    18,047
    The problem I see with a solar battery charger, is you must have the charger in the sun. I presume most are not going to leave their Ferrari outside, baking the leather dash in the sun (as well as the rest of the car), so that entails running a longish cord (and resistance the cable adds) from the solar panel to the car. (also risking theft of the panel). Just more to think about.
  11. f355spider
    18,047
    Is the car port illuminated with overhead lighting at night? If so, there is a way to tap into that for a battery tender. Either McGuyver it, or hire an electrician. Just make sure if it is only powered at night, that your battery tender does not require an "activation" step like pressing an "on" button or selecting modes. Those type of tenders do not automatically restart when power is restored.
  12. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    A solar charger won't put out enough current for the longer cable to be any issue. The idea about the light is good. If it is a edison socket you can get a screw in plug and you are off and running.
  13. ttforcefed
    ttforcefed F1 World Champ
    19,257
    just shut the battery off with the oem switch. i do it all the time. no issues. it will fry the ecu yada yada....it doesnt.
  14. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    It depends on the car how long it will last, I find even the same car but different years drain at different rates, my 2014 458 spider was terrible even if on tender did2like to start in the cold, this 2015 even after months parked up starts right up straight off the button although this winter has been particularly mild in London
    Sent from my CLT-L09 using FerrariChat.com mobile app
  15. 9650max
    9650max Karting
    173
    The Priority Start device installs between your positive post and your positive cable. If your battery discharges to a certain level it shuts it down so you have energy left to start your car.
    prioritystart.com
    PTG1 likes this.
  16. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Poor choice since you have a start sequence when you turn the power on, at least if you want it to run right. It would clear all codes so you could never diagnose any issues, and may never see them until it is too late. And, you could never pass a smog since no monitors would be set.
  17. nickorette
    nickorette Formula Junior
    Jun 19, 2017
    375
    Canada
    I also live in a condo, and my solution is this mega capacity li-ion portable power station:
    https://www.polaroidenergystorage.com/en/polaroid-ps600/
    I plug this in to the tender and gives about 2 days of power to tender. I switch it out and make sure it's hooked up to power up once a week. In the long winter months when I know the car won't be driven I disconnect the battery for convenience's sake
    crazy canuck and f355spider like this.
  18. f355spider
    18,047
    Thanks pretty brilliant solution. Someone else was doing that as well using a starting power pack they bought online. I forgot about that.
  19. crazy canuck
    crazy canuck Formula Junior
    Jun 20, 2005
    426
    West Coast
    Cool idea.
    I wonder if there is one that provides a trickle charge - but for longer than 2 days. ?
    Battery tech has improved quite a bit - so perhaps there's an option now ?
  20. nickorette
    Jun 19, 2017
    375
    Canada
    You can buy bigger Li-on batteries, but they get larger and more expensive. The PS600 gave me good balance between price, capacity and size. I think they are discontinued, but you can find similar size/capacity li-on batteries on amazon. Never had any problems and my cars can sit for 2-3 weeks sometimes
