488 - Maintenance, Fluids Change | FerrariChat
488 Maintenance, Fluids Change
Discussion in '458 Italia/488/F8' started by dgl36, Jan 26, 2025.
  1. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    I'm doing a full fluid change. What is everyone using for fluids:
    1. Engine Oil
    2. Transaxle
    3. DCT
    5. Brakes
    6. Power steering
    7. Coolant
    I'm finding the Ferrari-recommended fluids are not readily available. What is everyone using as an alternative? What is Ferrari recommending? I downloaded a 488GTB WS manual, but much information is missing. Please mention fluid capacities. Nothing is mentioned in the WS on capacity--the table is not included in the manual.
  2. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    536
    Trevor H
    Engine Total system capacity 10.5 l Engine oil SAE 1) 5W-40
    API 2) SN/CF ACEA 3) A3/B4
    SHELL HELIX ULTRA SAE 5W-40
    Oil level between Min. and Max. 1.5 l Oil consumption 1.0 - 2.0 l/ 1,000 km
    Gearbox and differential 3.4 l Transmission fluid SAE 1) 75W-90
    75W-90 SHELL SPIRAX S5 ATE 243
    Clutch system and hydraulic controls 7.55 l DCT-F3 or equivalent SHELL DCT-F3
    Braking system 1.0 l DOT4 4) PETRONAS TUTELA TOP5FF or SHELL BRAKE AND CLUTCH DOT4 Ultra 245
    Cooling circuit 19.7 l Prediluted antifreeze/coolant CARIX Premium Longlife mixed with 50% demineralised water
    Hydraulic power steering system 1.8 l CHF 11S or equivalent PENTOSIN CHF 11S 244
    Fuel tank 78 l (at least 95 R.O.N.5)) Reserve 13 l
    Air conditioning and heating system
    Compressor 165 cc PAG ISO 46
    Coolant 650 ± 30 g HFO 1234 YF HFO 1234 YF
    dgl36 likes this.
  3. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,293
    AUSTRALIA
    ANGELO
    I guess you are new to the 488GTB ? Make sure recalls have been done.
    One involved the Evap canister and the second the cap of the refill brake fluid reservoir
    dgl36 likes this.
