Maintenance?....... | FerrariChat
Maintenance?.......
Discussion in 'Ferrari Discussion (not model specific)' started by cgunner1, Jan 24, 2007.
  1. cgunner1
    cgunner1 Rookie
    Jan 22, 2007
    5
    St Augustine, FL
    Hi. My name is Charles and I am very new to this forum. I do not own a ferrari at the time, but I am looking forward to purchasing one in the next 5-7 years. I have read certain things about maintenance fees that have turned me off for all of the 12 cylinder cars (Testarossa to be exact). So I'm going to get a 355 or a 360. One I love the looks. Two, I love that there is an aftermarket for these cars. So..... to the point. How much are the maintenance fees for these cars? Annuals and so on. Thanks for the help.
  2. JAYF
    JAYF Formula 3
    May 13, 2006
    1,140
    Westchester, NY
    Jay
    Do a search , you may find that 355's are no more or less expensive to maintain than a Testarossa. If you want maintanence friendly , buy a 328.
  3. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    If you're looking to buy in 5-7 years and you want a low maintenance V12, the 550 might be the way to go.
  4. Dane
    Dane Formula 3
    Apr 25, 2002
    1,512
    Welcome to the chat. I concur with trying the search function. I guarantee you will find a ton of information concerning F-car maintenance and costs.
    The bottom line is find a car, have it PPId and go from there. The money for a PPI is worth it, believe me. Budget not for the car you can afford but the car you can afford to buy and maintain. Having said that, I still believe the best, basic preventative maintenance one can do is to simply drive!
    Good luck and, again, welcome to F-chat.
    d
  5. wetpet
    wetpet F1 World Champ
    10,210
  6. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Get a 328. 355/348 is no less expensive than a Testarossa. All require a engine out. The 308/328 can have a major service done without removing the engine. For more info the search feature is your friend.
  7. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Get the TR...while maintenance may be a little more than a 308/328....look what you get! Don't settle ...you will never experience what Enzo intended with a V8. If you can only afford a V8, just buy a Corvette...
  8. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    Welcome to the forum.
    I would recommend buying the newest model you can i.e a F430 is better than a 360 better than a 355 etc.
    If you drive a testrossa I think you will find it very dated. The chasis is stiff. I wanted to buy one and was back from the test drive in two blocks.
    Avoid 308's from what I have read they are expensive and troublesome.
    I have limited Ferrari experinece but my 360 was perfect and F430 thus far.
    The older cars have the advantage of being less electronic so you can go to private shops pay less and usually get good service. I must admit I love the appearance of thr 348. They meet the critera stated above. First of the modern Ferraris yet simple. Other people would know more about them than I.
    Good luck on your choice.
    Lee
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #9 Napolis, Jan 24, 2007
    For Japan I'd avoid a TR as it very wide. Maintenance is very high with a TR I'd figure $1.50 per mile.
    In 5 years TR gearboxes will be scarce as well and they go at 85K miles and are about 20K today installed.
    360's are a good choice and I'd also consider a 308 GTB/S or a 208 GTB Turbo if you can find one.
  10. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,597
    Gates Mills, Ohio
    Jon
    If you like the 360 more than the Testarossa, go that way. I think you'll spend significantly less repairing/maintaining it due to age, the fact that the Boxers and Testarossas have an expensive Achilles' Heel in their breakable differentials and that they require expensive routine servicing. The 355 does seem to be the most expensive of the V8s to maintain.
    I own a 328, and would agree they're probably the most "affordable" to maintain. They are older cars, though, so make sure you like the unassisted steering, tight cockpit, and low (by modern sports car standards) horsepower. IMO, the 308/328 are the prettiest of the lot, followed closely by the 355. That's what you get for foregoing the 355's vastly raised power.
    With regards to V8 versus V12, the V8 was made the dominant Ferrari engine under Enzo Ferrari's watch (the F40 was his ultimate car). It's probably fair to say, roughly, that the first 30 years of Ferrari road cars were dominated by twelves, and that from the mid 1970s through the present the V8 has been Ferrari's engine of choice for its sports cars, with the twelves powering the grand tourers and of course the few hundred Enzos.
    All of which is a long way of saying: choose the car that you love to drive and don't get hung up on cylinder count. A 360 and TR are very different cars and both great in their own ways. I like the 550/575 suggestion above - stunning car, inside and out, and probably the best thing Ferrari's done since the Daytona. If I could afford it comfortably, I'd have a 550/575 parked next to the 328 and not feel it was any duplication whatsoever.
  11. cgunner1
    cgunner1 Rookie
    Jan 22, 2007
    5
    St Augustine, FL
    Thanks guys. I really appreciate the info!
