Major Belt change being done ~ Any tips on questions to ask or other items to check? | FerrariChat
Discussion in '348/355' started by F355f1spider, Nov 11, 2013.
  1. F355f1spider
    F355f1spider Rookie
    Nov 8, 2013
    5
    I'm having my Major Engine-Out belt change on my 1999 355 F1 Spider 16,000 miles. Any tips on questions to ask other than the big one "$COST$". Other things to be checked while there and things to watch out for?? This is my first time on an engine out..
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,525
    San Carlos, CA
    Mitchell Le
    Please check my: hydraulic lifters, and oil pump tension pad.
    Do you rebuild my water pump?
    What brand of tensioner bearings do you recommend?
    Do you replace all the coolant hoses?
    You plan on cam timing the engine, right?
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,323
    Palos Verdes
    Vince V
    Don't forget the thermostat!
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
  5. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    It may be too late but it really depends where you bring the car. If you bring it to a shop that knows 355s and I sure hope you have then they will know all the things that should be done. So where did or do you plan on bringing it?
  6. JRLew
    JRLew Karting
    Jul 12, 2012
    71
    Indianapolis
    All good questions. What brand of tensioner should be used? Also, this may be naive of me but, cam timing..as opposed to?
  7. F355f1spider
    F355f1spider Rookie
    Nov 8, 2013
    5
  8. F355f1spider
    F355f1spider Rookie
    Nov 8, 2013
    5
    thanks for all of the good advice
  9. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    Do a smoke test on the headers ( if OEM ) to make sure that no leaks are present.
  10. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    Cam timing the engine as opposed to the lock and swap method. Which locks the cam gears whilst changing the belts, a lazy and faster way out of doing proper job.
