Major Failure - F355 broken prop shaft | Page 2 | FerrariChat
Discussion in '348/355' started by Fredmec00, Apr 11, 2016.
  1. st4rk
    st4rk Formula Junior
    447
    Yep!
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I would like to know who makes them for you to see what cost is
  3. phrogs
    phrogs F1 Veteran
    7,368
    Kzoo Michigan
    Invougjt a 355 like this, then i have seen a hand full of issuues of these breaking.
    Very rare in my opinion. Thats why you have never seen one.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The shaft needs to be hard for wear. Needless to say it must be tough. Toughness, and hardness for wear is a balancing act. Too hard = too brittle. The right balance of hardness for wear and toughness is required.
    Based on the fracture, my guy tells me the hardness is over 50 Rc. That's dangerous depending on material. 45 Rc is likely the better option.
  5. phrogs
    phrogs F1 Veteran
    7,368
    Kzoo Michigan
    Dave incoukd send you a broken one for testing
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Do you have dual mass or solid flywheel?
  7. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    Stock, dual mass. The seals are intact and grease in place I have not phisically checked myself as I am on a business trip for the hole month. The workshop garantees the flywheel dampening system is fine and there is no need to refurbish
  8. jmnov
    jmnov Karting
    Mar 15, 2009
    163
    Lausanne
    My car has the same failure:
    had to drive a few miles with 4 cyl, and then when starting on 1st gear the prop shaft broke...
    First thing to investigate is why it works on 4 cyl (only after heavy rain, might an electrical problem)...
  9. Fredmec00
    Fredmec00 Rookie
    Apr 11, 2016
    29
    Brazil
    Frederico Oliveira
    Mine was an intermittent failure in one of the fuel pumps. Expensive fix this prop shaft and hard to get your hands in one.
    I used this opportunity to change clutch as it was reverse-slipping (rpm drop) when half of the engine would loose power in high gear. I have a video on it.
    You will have to drop the gearbox to replace the shaft. before reassembling, it is also a good idea to balance the assembly clutch/flywheel/damper. It is a good practice, as such parts spins up to 8 000 rpm
    Keep sharing what you find, so other member dont have to go throught the same!
    Good luck!
    Fred
  10. jmnov
    jmnov Karting
    Mar 15, 2009
    163
    Lausanne
    I think I will go for the shaft made by Formula GT in Germany, maybe to change the flywheel in the same time...
  11. f355spider
    f355spider F1 World Champ
    18,056
    Will require further diagnosis, but one common cause is failure in the catalyst protection circuit. If the catalyst ECU fails, or acts up, it will shut down one bank. This is what it is supposed to do if it detects an overheat situation with one of the catalysts. Instead, this system is fraught with failures, and the causes inadvertent shutdowns of one bank when not actually required.
    Determine which bank is shutting down, and swap the catalyst ecus and see of the problem moves to the other bank.
    Another cause can be the catalyst thermoprobes can fail. But start with the catalyst ECUs...a known weak point.
  12. fatbillybob
    Aug 10, 2002
    29,360
    socal
    Can't be the problem. Internet experts here say these cars are perfect in the rain.
  13. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Yes, of course this is how the BS about these cars starts. 1 car out of a 1000 has an issue that MIGHT be attributed to something getting wet and the 999 owners that never have an issue are all wrong and the cars should never be driven in the rain or even washed with water.
  14. phrogs
    phrogs F1 Veteran
    7,368
    Kzoo Michigan
    They shouldnt have any issues driving in the rain.
    They came with wipers.
  15. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Hey, I wondered what those floppy rubber things were! Mine are new and never used. I replace them only for the aesthetics and appearance. I assume they function, but I won't tempt fate.
  16. 97spiderman
    97spiderman Karting
    Dec 15, 2008
    107
    Sunny Buffalo, NY
    JohnAG
    I suppose a plus within this story is, our 5 valve engines have enough power to snap (shear) these prop shafts. Now thats some powa
  17. jmnov
    jmnov Karting
    Mar 15, 2009
    163
    Lausanne
    Some news about my broken shaft:
    Bought the one from Germany (Formula GT), looks much better than OEM my mechanic says, should not break again!
    Installed and now he just need to change to spark plugs connectors and I'll have my car back on the road!
  18. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    So your bran new shaft looks better than your broken remains of your old shaft? Not much gets past your mechanic:D
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Good one ha ha.
  20. Jon Von Bon
    Jon Von Bon Formula 3
    1,697
    Toronto / Florida
    Jeff
    Great Marius. thanks for the link.
    Gives me an excuse to get to Frankfurt and take my monster back to Bavaria!
  21. Culprit
    Culprit Formula Junior
    509
    Santa Ana, CA
    Ian
    so next time when you're having severe engine trouble let's not rev it to 7000rpm
  22. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    My shaft just broke too and in the interests of getting ready for the Maranello Cup at VIR next week I am fitting a used one. Formula GT does not have these listed on the link we are using in this thread so do you happen to know if they still sell this product.
    My shear was in the same place and also caused by rough running. An intermittent misfire between 7300 and 7800 rpm that has been around for some time. We have tried everything to sure including replacement of crank and at least 2 rebuilds. The car is a CH model and is only used for racing. No cruising, DE, or display.
  23. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    If they don't still sell these, it appears that secret sauce is to anneal the last inch of the shaft closest to the clutch in order to make the shaft less susceptible to work hardening and snapping. Whether it is fully annealed or what the final hardness that results in the best outcome is unknown, but at least you have a direction to experiment in.
    Good luck
  24. HCF-John
    HCF-John Rookie
    Jan 30, 2018
    9
    John B
    It doesn't look like they do anymore. Does anyone know if there are other sources for these?
    Mark - if it's anything like the Testarossa prop shafts, if you make them stronger you move what gets damaged from one highly expensive shaft (prop) to an outrageously expensive one (main)!!
    Best,
  25. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    I like forumla GT's fancy clutch and flywheel parts. Man, those are sweet.
    sjd
