Major service on my 348 | Page 2 | FerrariChat
Discussion in '348/355' started by Cauf61, Jan 2, 2018.
  1. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    Ajax de 1e, Fumacher and fedgery77 like this.
  2. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Anybody has a good idea what the weight of this complete subframe is ? 350-400 kg ?
  3. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Cam belt tension ; do you rely only on the tensioner , measure the tension of just the old 90° twist method ?
  4. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  5. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    36 mm Crankshaftbolt looks going to be an PITA.
  6. AceMaster
    Feb 6, 2009
    34,790
    Ontario, Canada
    Why? An air gun should zip that off no sweat
    SoCal1 likes this.
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I used an air chisel on my diesel, couple pops loosened it right up.
  8. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    Milwaukee M18 Fuel 1/2" cordless impact driver will make very quick work of that bolt. 1100 lbft breakaway torque.
  9. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  10. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    #35 Cauf61, Jan 20, 2018
  11. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Oil pan is difficult to get loose. You only have to remove all the 13 , 10 and 17mm bolts yes. Not famous copper bolt on the bottom of the oil tank.
    magisano likes this.
  12. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    So what part of the job is difficult? Thinking of dropping mine to reseal with Hondabond.
    Sent from my Pixel XL using Tapatalk
  13. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    nice job
    13DM likes this.
  14. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Getting the bond loose was PITA. It took a very, very long time carefully breaking it with pulsating force with a 2 meter long small wooden beam and a lot of WD40. All very carefully.
  15. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    I see. Sounds like yours was properly sealed. I doubt mine is since it is currently leaking from a few different spots!
  16. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  17. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    And don't forget to undo the gearbox connection part. ( like i first did )
  18. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    I also found something very strange on the bottom tensioner. Look very carefully but i think the fixed arm should be on the other side from the spring arm. Not ?
    The fixed arm seems also bended. I will look in to it this evening.
  19. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    Can you post more pictures of how to trow down the engine please thanks
  20. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  21. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  22. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  23. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    steved033 likes this.
  24. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
