Buy
Making Ferrari shifting easier
Discussion in 'Technical Q&A' started by 348SStb, Apr 25, 2004.
  1. 348SStb
    348SStb F1 Rookie
    My brother likes my 348 coupe, but he says he wouln't want one for himself because the shifting is too much of a pain in the a-s-s.
    We all know that the older Ferraris take some effort and precision to shift. You can't just lollipop these cars into gear. Is there anything that could be done to make the shifting easier--like 355/360 ease? Or even Porsche-like ease? I don't have any experience with fiddling with gearboxes.
    I want to put him in an older Ferrari!
  3. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    16,919
    The Cold North
    Tom
    Unfortunalty making the 348 shift better is a bit of a trick. The 348 uses a push-pull cable system for the shifting. If not adjusted correctly it will be a stubborn unit to shift. The 355 went back to a shift rod which is much nicer. But for the 360 ferrari went back to useing cables and they shift quite nice. The only thing to do is trial an error to find the sweet spot were everything is working as it should, and feels right. This may take a couple of goes but it's not that difficult. Just remeber a little goes along way with these car so don't go turning stuff like crazy, you'll just end up worse.
    You could also try a different gear oil like a good sythectic like Amsoil or redline oils. They do seem to make a big inprovment in these car as far as shift feel goes.
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    8,153
    Perhaps you should teach him respect, first.
  5. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    There are modified shift gates available, e.g. from Paul Hill, which claim to make shifting from 1 to 2 and from 3 to 4 easier. I have not tried them yet but would be tempted to buy one.
  6. dm_n_stuff
    dm_n_stuff Global Moderator
    Global Moderator Lifetime Rossa Owner
    Dec 10, 2003
    38,182
    Babcock Ranch, FL
    Dave
    Tom.
    does the same apply for the 246GT? Push pull? My Dino is quite stiff to shift.
    How's that project Dino coming along, BTW?
  8. tbakowsky
    Sep 18, 2002
    16,919
    The Cold North
    Tom
    The Dino is also a shift shaft..no cables. You might want to try an adjustment of the shifter rod. Not very difficult to do at all..but again of your not used to doing it, it may take a couple of tries to get it just right.
  9. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    886
    Don't over torque your rod
  10. fatbillybob
    Aug 10, 2002
    22,435
    socal
    Try in order:
    shift linkage draggin chaffe. I have seen the cable even crushed by jacks!
    gear oil change
    shift linkage correction
    most popular oils
    mobil1
    redline mix mtl and the other I forget
    royal purple
    amsoil synthetic
  11. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Also be sure your clutch spigot (input shaft) bearing is free, be sure the centre plate(s) is(are) free to slide nicely on it's(their) input shaft splines and that the clutch is not dragging for adjustment or clutch bleeding problems, depending on model.
    Make sure all engine mounts are in good condition (oil contamination most common problem) and no excessive slack in any linkage bushes etc.
  13. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    I had one of these gates fitted to my 328,and I can confirm it makes shifting much easier,in fact i did not miss a gear once after it was fitted.
    Dave Mc
  14. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,245
    Commifornia
    The Bad Guy
    Being that the 355 has the same base for the body as a 348, I wonder if the shift shaft for the 355 could be fitted to a 348?
  15. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    Go to the Hill Engineering site and read my testimonial. You can click up top as they're one of our sponsors.
  16. Smiles
    Smiles Moderator
    Moderator Owner
    Nov 20, 2003
    15,908
    Pittsburgh, PA
    Matt F
