Manettino Failure - CST System Failure | Page 2 | FerrariChat
Discussion in '612/599' started by bob44, May 17, 2016.
  1. Alan McGrath
    Alan McGrath Rookie
    Jul 2, 2018
    31
    Los Angleles, California
    ALAN McGRATH
    Will do, thanks
  2. nickmaris
    nickmaris Rookie
    Nov 1, 2012
    4
    Switzerland
    nick maris
    Regret seen plenty of times on my 599, over many years and so far unfixable by three different authorised Ferrari service Centers
  3. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    I have a new to me 599 and this is happening to me too. Battery is 2 years old… who knows if it was kept on a maintainer? Looks like i need to check the battery out. The issue happened 3 times now… it did put me in wet mode but no issue with driving .. not in limp mode or anything.
    I want to make sure nothing serious is wrong.
  4. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    So so far this is just a battery issue
  5. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    Don't I wish!!!
  6. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    What is the issue with yours?
  7. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    I have a "manettino failure" but the code is unknown. I replaced the battery, and the code returns immediately. I suspect it is a wheel speed sensor or another sensor in the transmission. I am not in limp mode, it shows slippery mode BUT the engagement is much too erratic for that to be true.
    Recently, things have been too complicated personally to dig into this (don't ask). Things are smoothing out now, so I am thinking I will get it sorted in the next couple of months. I am looking forward to driving the Ferrari again.
    technom3 and gsworld2014 like this.
  8. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Interesting… let us know when you figure it out
  9. DouglasNg
    DouglasNg Formula 3
    Jun 6, 2004
    1,041
    SG
    Douglas
    Try checking the body control module, age related electronics
  10. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Which battery do you have?
  11. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    How did you figure out it was a sensor?
  12. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    This is happening to me. No limp mode just puts me in wet mode. Doesn’t happen every time. Just every once in a while. Kind of annoying .. put a new battery last month.
  13. Caeruleus11
    Caeruleus11 F1 World Champ
    11,720
    My mechanic diagnosed the problem and reported back to me it began with a parking sensor failure- it was hit by a pebble on the highway. Go figure!
  14. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    That’s Crazy.. I get it every once in a while but I cycle the car and it doesn’t come back for a while… very odd
  15. ViperGTS
    ViperGTS Karting
    Jan 24, 2023
    85
    Konrad A
    Reviving this thread. On my 2007 599, I diagnosed the problem to the switch that is at the top of the brake pedal (green dot on the picture). At the age of our cars when the weather changes (like it gets very cold) the plastic piston that is actuated as a consequence of the brake pedal gets "stuck" in the "no pedal input" position, and that is what triggered the code for my car. Short term solution was to spray WD-40, that did the trick. A more permanent solution would be to remove, clean, properly lubricate, and reinstall the piston at the end of the switch.
    brogenville and Skidkid like this.
  16. gsworld2014
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    My Issues seem to be the battery. I replaced the battery and it was still doing it so I thought it was an inclination sensor draining. I changed my battery maintainer to Cteck since I Bought an odyssey battery.. Seems to be all good now I haven’t been getting any stupid messages
  17. ferrarinewbie28
    Dec 15, 2023
    25
    Seattle, WA
    I had the Manettino failure when my potentiometer in the F1 system went bad. Seems like just about any electrical issue can trigger this
  18. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    213
    Madrid, Spain
    F3RN
    I have suffered this Manettino failure in one of my 599s recently.
    Believe it or not, it was due to a MAF sensor not working properly..
    They replaced both and the failure is gone.
    Skidkid likes this.
  19. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    Thank you everyone for providing data points for this. I trust it will help others well beyond me.
    I haven't had the time to dig into this yet; yes, I make slow progress given too many projects. I am confident that my MAFs are F'd, there was visible oil burn because a shop overfilled the system. I decided to start by replace the MAFs, fix the bumper (scrapes & an embarrassing story involving backing onto my lift), and replace the battery. I had replaced the battery, but it died in the first 2 years even though it was on a maintainer. THEN, I will see what codes remain. Hopefully that fixes stuff, but I am not confident that will happen. At least it will reduce the competing errors and make the issue easier to track.
    I caught up on most of my bigger projects so I will dig into it after the holidays.
    armedferret and technom3 like this.
  20. Racerjohn
    Racerjohn Karting
    May 29, 2018
    65
    California
    Was the car running roughly?
  21. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    213
    Madrid, Spain
    F3RN
    Yes, it was.
