manual 400GT clutch replacement | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Jaredsalinsky, Sep 3, 2024.
  1. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Hello manual 365/400/412 owners.
    I was hoping to begin a discussion about the clutches on our cars since I believe mine is due for replacement. I have already purchased the necessary parts from Eurospares and will hope to have this done in the next few months (when it gets a little cooler in florida).
    My odo only has 60k km (38k miles) and the clutch engagement point is VERY high up; like my knee is almost in my chest! And of course I did the slip test... and it definitely slips in the higher gears.
    I read some of the older posts regarding how 'hard' they are, and mine is no different. I would expect that once I replace the clutch...this will not improve... That's OK.
    Does anyone have any advice, recommendations, or anecdotal opinions, pearls, or pitfalls?
    thanks in advance..
    Jay
    Schumi likes this.
  2. Britward
    Britward Karting
    Sep 8, 2021
    97
    SF Bay Area
    Rob Ward
    My 412 is at a similar stage at similar mileage.
    Clutch bite point is perhaps 2-3 cm from the top of the travel, although I haven't yet felt any actual slippage.
    How did you do your slip test? Wouldn't it be more likely to slip in the lower gears, first and second, than the higher gears?
    I'm usually one for preventative maintenance, but this one I'll wait for...
  3. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    I know there are several ways to do it and I’m sure that some people have better ways than others. And I’m sure there are precise technical ways to check the clutch.
    Obviously, if you’re engagement point is getting higher and higher that certainly indicates problems. Or if you smell burning clutch that also seems pretty obvious.
    The two ways that I check slippage is simply to try and start the car in third or fourth gear and see if you can actually get it driving (gear engaged and car accelerating) without stalling. A similar technique is to be moving maybe 30 miles an hour and then put the car in the highest gear and ‘floor it’ and see if the gear engages and you accelerate, or if it just ‘slips’ with the RPMs going up but the car not accelerating.
    To your point, why not check slippage in the lower gears? Because if you’re slipping in first gear, it’s already too late! You can’t get home!
  4. Rifledriver
    36,819
    Silly I know but just a thought. Have you adjusted it?
    Ak Jim and skl63 like this.
  5. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Admittedly, I have not… But that is definitely something I will look at as I begin to dive in to all the clutch related parts, both in the cabin and under the car.
  6. Rifledriver
    36,819
    Sorry, could have sworn I was on planet Earth.
    Carry on.
    3500 GT likes this.
  7. rovexienus
    rovexienus Formula Junior
    587
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    Might not be exactly the same parts on the 412, but the principle of clutch pedal adjustment ought to be close enough.
  8. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    very helpful. thank you. I will check this out next time I'm in/near/under the car!
    cheers
