Manual clutch replacement??? | FerrariChat
Discussion in '360/430' started by Chiaroman, Jan 11, 2011.
  1. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Dear All,
    My 2004 360 manual has 15,000 miles.
    No clutch symptoms to speak of.
    When do you replace the clutch?
    Is it a time issue, mileage issue or when it stops working?? (not fun...happened in my 308)
    Do you get symptoms? If so...what should I look out for???
    I realize that if I have the dealer open it up and look at it the labor involved would preclude having something done.
    Thanking you all for your expert help.
    Yours,
    Tom
  2. away
    away Formula Junior
    Aug 5, 2004
    635
    Lansdale, PA
    Andrew
    Tom,
    At 15k you should still be okay on a 6 speed. (it's life varies based on use/abuse) When the clutch starts slipping or acting up upon engagement, then have it into the shop. In the meantime, enjoy it!
  3. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    i have a sixer and heard basically the same symptons as any other auto. while we are on the subject, wouldn't a clutch replacement be less on a manual than on the F1 since less parts/electronics?????????
    Don't kick me if that was a ignorant question. my son went mike tyson on my head today
  4. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
  5. Rifledriver
    37,103
    One part is different and an F1 is easier.
    Its nearly a wash.
  6. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Thank you for all the reply's!!!!
  7. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    One thing I have always wondered is why the clutch in a manual Ferrari (or Maseratis of the last decade, or current Lambos) have such a short lifespan compared to "normal" cars with similar horsepower numbers.
    Is it that the cars are just driven differently? Are the exotics used for more city stop-and-go driving, or do they typically see more time on the track?
    I always wonder when people say they only get 10-20,000 miles out of a clutch how they used the car, or whether that sort of rapid wear is designed into the product in the first place.
    If you were to take say a manual C6 Corvette and just drive it like a normal car without abuse the clutch would last many tens of thousands of miles, how long would a clutch in say a 360 be expected to last with the same driving?
  8. sidned
    sidned Rookie
    Jun 16, 2010
    38
    Northampton, UK
    Darren
    My manual 360 had it's first clutch at 26,000 miles. It was just before I bought it so I don't know what it drove like beforehand.
  9. Bebs
    Bebs Formula Junior
    Jul 12, 2010
    277
    London, UK
    I have changed clutch twice on my manual. Once at 30,000 miles and again at 80,000 miles
  10. bobby355
    bobby355 Karting
    May 21, 2009
    244
    45k miles still on orignal clutch
  11. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    That's what I want to hear!!!!
    HEE HEE!!!!
  12. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    We have clutch masters upgraded clutches instock if any one needs one.
  13. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Yeah, mine was first done at 40k miles and had been through three different owners at that time.
  14. DrivnXcitment
    DrivnXcitment Karting
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    A lot of why you hear of Ferrari and Lambo clutches going early (15-30k) is that they are physically smaller than lets say a Corvette. The smaller diameters have less rotational mass and therefore less parasitic drag creating higher horsepower (generally measured at the flywheel or rear wheels, sometimes at the crank but not as common)The smaller clutch still has to do the same duty as a bigger clutch with high horsepower, therefore resulting in more wear on the smaller surface. Hence the shorter life. You can get kevlar clutches for more $$ but they will last you a lot longer.
    All this being said, driving style has A LOT to do with how long your clutch lasts as well. F-1 and E-gear trannys tend to "ride the clutch" a lot more than someone who is proficeint at driving a manual transmission. There are certain ways to drive those automated manuals and if you do them, they will last a lot longer than 15k.
    Just my two cents, hopefully it helps some.
  15. needspeed
    needspeed Formula Junior
    Oct 5, 2006
    579
    Middle of nowhere IA
    Steve
    I am still new to this, but my F430 has almost 9K on it with 25% F1 clutch wear. So I am hoping for 30K, maybe 40K if lucky, so I will be happy with that.......Steve
  16. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Happy and very lucky it would appear!
