430 - Manual Conversion Shifter Linkage Routing | FerrariChat
430 Manual Conversion Shifter Linkage Routing
Discussion in '360/430' started by GogglesPisano, Jul 9, 2024.
  1. GogglesPisano
    GogglesPisano F1 Rookie
    3,344
    East Bay, California
    Joe
    Wanted to post this here to the larger community to see if other people have taken different approaches. I'm sure @modificator has the answer but curious if anybody has done anything to alter routes, etc.
    At the linkage install portion of my manual conversion. I have a late 08 MY car so there were already a few holes plugged, etc that made it different from the picture heavy install guide. At the cable routing stage though and the picture in the guide is from a 360. The F430 has a filter in this location which forces you to sort of kink one of the cables upward. Not a huge deal but was it like this from the factory? The slight bend makes the upper cable have more resistance when sliding back and forth. Should they go to the side of the filter? I noticed on NGSC video that his was about the same.
    Thoughts, feedback, etc?
    Thanks.
    First picture is the 360 in the guide and second is how my cables are sitting right now
  2. GogglesPisano
    3,344
    Joe
  3. LorenzoR
    LorenzoR F1 Rookie
    There is a bracket a little further back by about a foot and a half. I'll see if I can find the picture
    GogglesPisano likes this.
  4. LorenzoR
    LorenzoR F1 Rookie
    Joe I think there's a bracket on the oil pump on oem manual shift cars. The f1 cars doesn't have that bracket. And from there forward to the car I don't remember. I can't find the pics and I'm not with my car
  5. robst
    robst Karting
    Mar 9, 2024
    119
    Houston
    Rob
    thank you for bringing this up.
    I guess this could be why there is further adjustment needed for 4th and 5th gear (IIRC).
    The "bend" adds slightly more resistance and length to the route of the cable compared to the 360.
  6. LorenzoR
    LorenzoR F1 Rookie
  7. GogglesPisano
    3,344
    Joe
    Wonderful! Thanks again!
  8. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,655
    San Jose
    dc
    I like your compulsive obsession attention to detail.
  9. GogglesPisano
    3,344
    Joe
    Not mine but my mechanic’s although my OCD does get the best of me sometimes. He even turned the clamps on my exhaust connectors because he noticed the threads were oriented in a way that was allowing moisture to drip down on them, making them rust slightly.
    Sj_engr and oc23 like this.
  10. AandSC
    AandSC Formula 3
    1,013
    Jax, FL
    Allen
  11. LorenzoR
    LorenzoR F1 Rookie
    Great pics. You can see the rubber grommet that the cables slide thru at the rear wall. Then the rubber/metal bracket, then the metal bracket at the pump which is not on a f1 car. I suppose something could be made for that. I can't see it on any diagrams
  12. GogglesPisano
    3,344
    Joe
    Mechanic ended up replicating the factory setup perfectly. Cables are as close to natural as you can get so no resistance in the motion.
