Manual F430 gear oil | FerrariChat
Discussion in 'Technical Q&A' started by PGH, Nov 5, 2022.
  1. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    I know several people have posted about this but I’m looking for a little more specific help. I changed my gear oil about 150 miles ago with Redline NS and I have chatter at slow speed turns until car is driven a few miles and then it’s gone. Shift are great! Is this damaging to the trans/diff? Do I add modifiers, if so how much? Do I need to put more miles before doing anything? I’m not opposed to changing the oil again if this is causing any damage. Please let me know what you all suggest. Thank you
  2. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    Sorry, forgot to mention it’s Redline 75w/90 NS
  3. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    I have a vintage V-12 with a transaxle. Several years ago I switched to synthetic LubroMoly GL5 SAE 75W-90 Gear Oil. I have had very good result with this gear oil, especially the 1 to 2 shift when the oil is still cold. Prior to the switch, I would have to shift from 1 to 3 before the oil warmed up.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    Add modifier 1 oz at time until noise goes away
    Marcoboxer and RayJohns like this.
  5. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    I just had a client with a similar issue. It was suspected the EDiff had an issue as he could not get the diff to be quiet. I disassembled it and found the clutch plates were dry of oil. As I removed the first floater plate, I could see the oil migrate across the disc. I cleaned it and soaked the discs in gear oil. I reassembled it and had no issues. I am told this car sat for sometime and this could account for the lack of gear oil on the disc. It could also be the trick oils they used trying to make it all better. I use Mobile One 75/90 LS. I haven't had any issues.
    ferrarioldman likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    I should have noted.. after adding do a few figure 8s backward and forward in a parking lot to get fluid into diff plates
  7. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    Thank you all for the post, I’ll have to get a new crush washer and add modifier.
  8. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    I've had good luck running Motul 300 gear oil.
    Limited slip differentials often require some level of friction modifier, otherwise they tend to operate like a spool or locked differential. I've had cases where I had to do just what Flash32 recommended, where you just have to keep adding 1 oz of modifier at a time until the chatter subsides.
    Ray
  9. windsock
    windsock Formula 3
    1,152
    We see this a lot and this is our go to stuff. One bottle will sort it out. Works great for the conventional differentials as well. Chatter is the biggest reason we went to the Shell 1099 fluid.
    f355spider likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    The GM one works well too
  11. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    I’m going to change the oil motul 300 (I think), it comes suggested from several mechanics. I’ll let you all know how it works. I hear the balance of adding FM can be a challenge.
    RayJohns likes this.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    If you are going to change oil consider Ravenol vsg
  13. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    The problem is I can only find royal purple, Mobil 1 and Valvoline at the local shops. If I pay a mechanic they have motul. All are full synthetic and I will change every year so I’m not sure the difference in all of them. I just want the chatter gone and my car is a manual transmission, I’d like smooth shifts. As long as they have FM should they work?
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    Order the Vsg .. you will be happy
  15. f355spider
    f355spider F1 World Champ
    18,044
    This answered the OPs question about his limited slip differential noise how?
  16. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    I've been running Motul 300 with excellent results. I've also used their 300V (I believe it is) in my street bikes and shifting is silky smooth.
    Go slow when adding friction modifier and give it some time to work its way around things. It's easy to add more, but there's no way to remove any once it's in there (even completely draining the gearbox or differential will leave some residue on the walls of the case, etc.).
    Check the Motul website for specifics and make sure you start off with the correct product. Their website (and their technical support over the phone) are both top notch.
    Ray
  17. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    Motul 300 is what you want...
    Valvoline is also top notch in my experience.
    Some of the Motul products are also double ester based as I recall. You might want to research all that. The motul 300 is a very good gear oil and sticks to everything. It's a trip.
    Ray
  18. PGH
    PGH Karting
    Aug 3, 2022
    87
    Arizona
    Paul Hobeich
    Thanks Ray. I’m going to put Motul in the car today. I’ll let you know how it goes!
  19. Marcoboxer
    Marcoboxer Formula Junior
    293
    Alpharetta, GA
    Mark Roberts
    I did exactly this, with this oil. Took 2oz on my car.
  20. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    Better lubrication of the LS differential clutches. Modern synthetic gear oils are designed to work well with LSDs.
  21. rkrkrk
    rkrkrk Karting
    96
    CT USA
    Resurrecting this old thread as I'm trying to find a good gear oil. Btw, the gear oil and rear diff oil is all the same in these cars, right?
    Are y'all finding that with Ravenol VSG and Motul 300, no chatter even without friction modifiers?
