Manual overide for 456 Seat | FerrariChat
Discussion in 'Technical Q&A' started by F456 V12, May 16, 2004.
  1. F456 V12
    F456 V12 F1 Veteran
    5,360
    Coto de Caza
    Christian
    My passenger seat will not move forward, back, etc and it is in a position such that I can't get to the rear bolts. Is there a manual overide for the seat such that I can move it forward? or a way to get the bolts out?
    Help is appreciated
  2. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    If it is like the 550, I doubt it.
    Did you check the fuses first ?
  3. F456 V12
    F456 V12 F1 Veteran
    5,360
    Coto de Caza
    Christian
    The fuse at the motor seems to be OK. I'm concerned the contol box under the dseat may be faulty. Fortunately, it boke in the right position so I can live with it if I have to
    MB
  4. kinnie
    kinnie Formula Junior
    Nov 21, 2003
    324
    Belgium - Aarschot
    Kinnie Van Gelder
    Hello,
    I'm currently parting out an 456. The passenger seat is ok, and as my memory is ok I think there is a fuse under the seat Have you cheked this one? I will see tomorrow what I can see under my removed seat. If you need parts to replace your faulty parts contact me.
    Best Regards,
    Kinnie
    www.ferrariparts.tk
  5. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    I really love 456's, but with so many quality issues I'm worried I won't ever want to buy one. Which is sad, because I really like the styling and the interior. But I wouldn't put up with the many malfunctions I keep hearing about and reading about.
  6. Kevin456MGTA
    Kevin456MGTA Rookie
    Jan 4, 2005
    7
    GAlveston, Texas
    Kevin C. Walsh
    I have recently had the same problem with my passenger seat.
    It was stuck in the rear position.
    I took it to FOH and they said the motor was out.
    New cost $1000.
    What about used parts?
    Kevin
  7. cgperry
    cgperry Formula Junior
    Nov 2, 2003
    506
    Chas SC
    Charles Perry
    If it's like most cars (including my 355 spider, Corvette, Durango, etc) then there is an electrical connection to the seat motor under the seat. If you can figure out which two wires go to the motor, you can manually connect 12-volts to them to move the seat. Connecting them in one polarity moves the seat one direction. Connecting them in the opposite polarity reverses the direction.
    If you connect 12VDC directly to the motor and get no response, that pretty much tells you the motor is dead, in which case I'm not sure how to get the seat to move to expose the other bolts.
  8. Rifledriver
    37,288
    That is the method I have had to use in the past.
