Maranello Water Pump leaks? | FerrariChat
Discussion in '456/550/575' started by 575M-Nero, Apr 15, 2007.
  1. 575M-Nero
    575M-Nero Formula Junior
    Feb 25, 2006
    524
    How common is this problem?
    My mechanic says he's seen it many times before.
    Am doing a rebuild for a leak right now at 5500 miles.
    TIA!
  2. of2worlds
    of2worlds F1 World Champ
    18,110
    ON
    CH
    not good. I am sure Brian will know the inside scoop! Good luck with your service work.
    CH
  3. Rifledriver
    37,106
    Water pump seals die more from sitting than from use so it is not altogether uncommon on Ferrari's in general. It is the same pump on a 355 and 456 and it is not considered a problem area. The seal itself is a very good design and is used as a retrofit on other models pumps. Regular coolant changes and regular use are the best thing for waterpump seals.
  4. 575M-Nero
    Feb 25, 2006
    524
    What is a normal price in USD to do a water pump rebuild?
    Thanks!
