Maserati 4.7 spark plugs.... | FerrariChat
Discussion in 'Maserati' started by Jorgen Andersson, Nov 25, 2009.
  1. Jorgen Andersson
    Dec 1, 2008
    77
    #1 Jorgen Andersson, Nov 25, 2009
    Hello
    What brand and model of spark plugs have you had best results with on this engine?
    Anyone have the stock number for the oil filter, Mann or any other European brand?
    Jorgen
  2. thecarnut
    thecarnut F1 Rookie
    3,232
    Atlanta
    The Car Nut
    I like NGK BP5ES for regular driving. Use NGK BP6ES if you like to drive hard for extended periods.
    Ivan
  3. Merak1974
    Merak1974 Formula 3
    Aug 31, 2009
    1,716
    Oslo, Norway
    Gabriel R.G. Benito
    Hi Jorgen,
    Your Indy looks great: Congratulations!
    I have never owned a Maserati V8, so this is from searching the net...:
    - Mann specifies W940/37 as appropriate for your car (Indy 4.7)
    - A suitable Fram filter is PH3616
    - Tecneco specifies OL34
    Those three should be easy to find in Sweden.
    - UFI lists 23.113.00, but you will probably have to order it from abroad.
    Hope this helps.
    Gabriel
