Maserati 4.9 V8 Engine | Page 8 | FerrariChat
Discussion in 'Maserati' started by Freitag, Jun 10, 2009.
  1. staatsof
    staatsof Nine Time F1 World Champ Silver Subscribed
    Mar 13, 2005
    96,488
    Fuggetaboutitland
    Bob
    When you put the engine on the dyno I'd be curious as what effect having a taller air filter box would have. A former Bora owner and friend of mine was convinced that the top cover comes too close to the top of the air horns.
    As you know I experimented with forced air via those rear quarter vents. No conclusions except that it didn't work too well in light rain.
    I also never understood the unusual shape of thosee air horns?
    Something out of Captain Nemo?
  2. emsiegel13
    emsiegel13 Formula Junior Silver Subscribed
    Oct 9, 2007
    544
    Grayslake, Illinis
    Elliot M. Siegel
    You, of all people, should know not to question Italian logic! However, perhaps they were worried about getting the spare tire out of the Bora without having difficulties with the air horns if they extended straight back over the spare.
  3. staatsof
    Mar 13, 2005
    96,488
    Fuggetaboutitland
    Bob
    They did an awful lot of things very, very right with that car. I like where the spare is located and the huge front trunk etc. But ... airflow to the engine and in & out of the engine compartment gets a big F.
    It's a great mid fall to early spring car.
    It's also a great car.
    What about my question the top cover to air horn clearance?
  4. MK1044
    MK1044 Two Time F1 World Champ
    Nov 6, 2011
    21,150
    NYC USA
    Carmine
    Hi Elliot,
    Let's see some photos of the progress. Internal work such as the smaller crank journals and the bottom end stiffeners would be interesting to me and I think others. But any photos you have would be interesting to see.
    Carmine
  5. bundas
    bundas F1 Veteran Owner
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    very slowly taking three QP 3's apart. lack of help has really been a serious problem as i am not willing to spend big dollars. can ship all three to u, for dollars, if interested. i just got too old too fast
  6. emsiegel13
    Oct 9, 2007
    544
    Grayslake, Illinis
    Elliot M. Siegel
    I'm off on vacation on Monday but when I get back I'll go to the shop and see if I can get some pictures to post. Bear with me, I'm Luddite when it comes to computers. I'll see if I can get my son to lead the blind man through posting them.
  7. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,296
    Harriman, TN USA
    Michael Demyanovich
    Bundas...
    PM sent....
    Mexico074
  8. licodix
    licodix Formula Junior
    Feb 7, 2009
    336
    Central
    Barchetta Mad Max
  9. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Nice find. They look like the ones on my Khamsin too, are they the same for Ghibli and Khamsin?
  10. licodix
    Feb 7, 2009
    336
    Central
    Barchetta Mad Max
    I am not sure, but it might be. Looks like this manifold is an interesting item if the quality is as the seller describes...
  11. velocetwo
    velocetwo F1 World Champ
    Dec 11, 2006
    12,545
    Left Coast
    I think a number of these parts were used on early BMW's too. ZF correct
  12. Falta125
    Falta125 Karting
    Mar 11, 2012
    112
    !970 Ghibli uses the remote oil reservior mounted near the brake canisters, if your car had a smog pump it will use the bracket on top of the water pump. The off set on the pulley is the same but you will need a 4 row pulley if you want to go that route. Front pulley is for the alternator. 2 pulleys in the center run the water pump and A/C and the forth is for the smog pump. Also if you go that route the alternator is backwards and you will need a reverse blade fan for proper cooling of the alternator
  13. licodix
    Feb 7, 2009
    336
    Central
    Barchetta Mad Max
    Today I have a question for the specialist:
    is the air box on Ghiblis the same as on Mexikos? I do not mean the filter, but the black plastic box? It looks the same, but I am not sure. Anyonw who knows???? Maybe does it fit for other variants of the V8? Thank you!!!
  14. wildegroot
    wildegroot Formula 3 Professional Ferrari Technician
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    It's been a while since I worked on a Mexico but if I remember right, a Mexico has DCND carburetors while a Ghibli has DCNF carburetors so the air filter housings are probably not the same.
  15. licodix
    Feb 7, 2009
    336
    Central
    Barchetta Mad Max
    You are right, the carbs are different for sure - but there are different undersides of these black air boxes (I am not sure if they are two pices - but I assume so, as there these famouse black screws to fit them together)
    ..anyone?
  16. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    If you have pictures of both engine bays and the two air "boxes" appear to match they probably do. If not, a close second can always be adapted but Maserati was a small company and would have tended to recycle a working part rather than make something just a little bit different. Unfortunately, there isn't a whole lot of documentation for the Mexico. All we have is an owners manual with no photos.
  17. licodix
    Feb 7, 2009
    336
    Central
    Barchetta Mad Max
    I checked some of the drawings, the upper part looks realy identical. Anyone an idea where ot find sucha part -and approximate costs? Seems the "normal" sources do not have it...
  18. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    The early Ghibli air box was made of fiberglass and I believe the Mexico air box was fiberglass also. If you can borrow one, you can have someone make a mold off of it and lay up a new air box. That's what we would do if we couldn't source one to buy.
  19. lussoman
    lussoman Karting
    Sep 7, 2008
    135
    Hey guys,
    I thought I would chime in, I know the mexico pretty well and am restoring my third one at the moment. The 4.2 liter Mexico's had 38 dcnl webers and the 4.7 liter cars had 40 dcnl 5 webers which are the same as on the ghibli.
    The air filter cover for almost all of the mexico's, most of them made in 1967 and 1968 had the two hole covers. The later " series 2" cars of 1970 had the 4 hole cover that are consistent with the four hole covers that are on the middle series ghibli of 1970.
    I have an extra 2 hole fiberglass cover in perfect shape if anyone needs one.
    Chris
  20. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,855
    Seattle
    Carguytour
  21. emsiegel13
    Oct 9, 2007
    544
    Grayslake, Illinis
    Elliot M. Siegel
    For those of you who may have a Maserati Bora, a company in England, Racemettle Ltd. now has a high torque geared starter motor specifically designed for the Maserati Bora. The first unit was built, fitted and tested on a Bora that was available at the Bill McGrath shop in England. It is a direct drop in replacement. The unit weighs about half of what the factory starter does, is much more compact, thus less susceptible to heat soak than the original, more powerful and draws less power during starting. So for anyone who wishes to replace your existing starter for any reason, check out the Racemettle website,
    Racemettle, to see what is available.
    71Satisfaction likes this.
  22. staatsof
    Mar 13, 2005
    96,488
    Fuggetaboutitland
    Bob
    OK but not just trying to be a contrarian here what was wrong with the original?
    If you have the heat shield in place it's never caused any issues for me. That includes 110F trips to Lake Havasu City, Arizona.
    Lighter weight is nice though.
  23. emsiegel13
    Oct 9, 2007
    544
    Grayslake, Illinis
    Elliot M. Siegel
    In my case, due to an attempt to add a dry sump system to a spare engine for my Bora, I needed additional room which wasn't available with the factory starter in place but which the Racemettle starter provided and also, in an attempt to add knock sensors to the block the only available location was a fitting on the starter side that was blocked by the existing factory starter. Also, anywhere I can take some weight out of the Bora without making any structural changes or modifications to the car or any of its parts is a plus. I'd love to take 50 to 100 kilos out of the car in a way that can be reversed easily just to have the additional benefits that come with any weight loss done right to an automobile. I didn't sucessfully give the Racemettle website. It is Racemettle for anyone wishing to take a look.
  24. MK1044
    Nov 6, 2011
    21,150
    NYC USA
    Carmine
    Elliot,
    Where's the beef? ;) Let's hear a progress report on your engine modifications and see some photos.
    Carmine
  25. emsiegel13
    Oct 9, 2007
    544
    Grayslake, Illinis
    Elliot M. Siegel
    I was at the car today with the electrician and by next week we should have the last part of the ECU harness in progress. I am pushing everyone to get the engine on the dyno this month. Unfortunately, it seems that it is always two steps forward and one step back. We have placed queries to Pectel and the US people have been helpful but unlike several other ECU manufacturers, Cosworth and Pectel never developed a manual for the Pectel SQ6M so everything has to be check and rechecked to make sure the harness is fabricated correctly. Of the 101 pins available on the Pectel ECU, all but a handful are being utilized right away with only a few being held back that are being reserved for a possible future drive by wire upgrade and a very distant maybe for turbo charging. Both my electrician and myself want to do this harness once and better to be doubly sure before we commit to the final part which leads to the various sensors and function. If I sound evasive, I apologize, because if anyone wants to get both engine number one and number two on the dyno, it is me. I guarantee you my frustration level is far above anyone else's. I beg your indulgence for a short time more. One final note, my children have labeled the Bora as the virtual car as they are not really sure that it exist except for all the receipts I have in my files.
    Elliot
