News
Maserati clock
Discussion in 'Maserati' started by Edward 96GTS, Apr 3, 2020.
  1. Edward 96GTS
    Edward 96GTS F1 Rookie
    4,080
    NOS clock but which model maserati model does this belong?
  3. red27
    red27 Formula Junior
    Sep 7, 2010
    587
    London UK
    Mark Oliver
    Wow. That looks really lovely - and is extremely hard to find. It took me 2 years and £400+ to get my non working one!
    Would be suitable for a Ghibli, Indy for certain. Khamsin And Bora/Merak I think have a different adjuster knob, but basically the same.
    Stay well everyone.
    Mark.
  4. Edward 96GTS
    4,080
  5. awohlmann
    awohlmann Karting
    Jul 6, 2008
    153
    Austria
    Alfred Wohlmann
    I have this clock mounted on my 70ies Ghibli #1155
    Alfred
  6. Edward 96GTS
    4,080
    ^ beautiful interior, love the color.
  8. Froggie
    Froggie Formula Junior
    Sep 27, 2017
    294
    Belgium
    Serge
  9. thecarnut
    thecarnut F1 Rookie
    2,525
    Atlanta
    The Car Nut
    ActuActually teh aaaa
    Similar, but not the same. If you look carefully at the Ghibli photo showing the clock you will see that the diameter is larger than the other gauges. The Indy 4700/4900, Khamsin, Bora and Merak used a smaller clock whose diameter was the same as the other gauges. Although no dimension was provided for this clock, the slot head screw in the adjustment knob would point me to think this is the larger version used on the Ghibli and perhaps early Indy.
    Below are photos showing the Indy 4700 and Khamsin clocks, which you can see are the same size as the other gauges.
    Ivan
    Froggie likes this.
  10. Edward 96GTS
    4,080
    another difference is the size and shape of the adjusting knob.
  11. thecarnut
    thecarnut F1 Rookie
    2,525
    Atlanta
    The Car Nut
    If you plan to sell it the prudent thing to do is to measure your clock's diameter so that potential buyers are better informed and do not end up with something that will not fit their car.
    Ivan
  13. Froggie
    Sep 27, 2017
    294
    Belgium
    Serge
    If I understand correctly with the picture shown by awohlmann, this clock was mounted only on Ghibli's or only certain Ghibli's, due to a larger diameter than standard.
    Was there a specific larger hole in the dash?
  14. awohlmann
    awohlmann Karting
    Jul 6, 2008
    153
    Austria
    Alfred Wohlmann
    Both of my Ghiblis had the clock with a larger diameter than the other instruments.This seems to be original, because the hole in the dash was correctly cut out - not a hand made larger one.
    Alfred
    Froggie likes this.
  15. Edward 96GTS
    4,080
