Maserati electrical problem | FerrariChat
Discussion in 'Technical Q&A' started by Tom308/430, Aug 25, 2024.
  1. Tom308/430
    Tom308/430 Rookie
    Jun 28, 2024
    1
    Tom Coffman
    #1 Tom308/430, Aug 25, 2024
    I have a 2008 Quattroporte. Recently while driving, the instrument panel lit up with warning lights (most all of them). I did the Italian reboot and all of the warning lights went out except for the airbag warning. Does anyone know of a way to reset that?
  2. Qavion
    Qavion F1 World Champ
    14,340
    Ian Riddell
    I would first want to figure out why your instrument panel lit up with warning lights (most all of them). This is not normal even on an "Italian car" (which probably has mostly German electronics).
    In general, airbag lights on cars of this era can be reset with an OBD reader if:
    You have a Maserati-compatible mid to high range OBD reader (with an airbag reset function) AND
    There are no non-resettable errors OR
    You go to a Maserati dealer
    Did you check your Owners Manual for an airbag fuse? Consult dealer if blown.
    This may or may not be the same as your car:
    Having said that, I know nothing about Maseratis.
    BAK5150 likes this.
