Maserati Ghibli (1966 - 1973) | Page 84 | FerrariChat
Discussion in 'Maserati' started by miuras, Feb 27, 2007.
  1. GrifoS2
    GrifoS2 Rookie
    May 20, 2007
    33
    Hello Julian,
    I bought four 20 cm long bolts and nuts, something between nut and spring pan,
    to have nuts in better position for turning.
    Then changed four bolts one by one, removed two bolts,
    and lowered spring pan down.
    It takes some time, but is safe method, as long you take care that only nuts turn,
    and bolts are tight.
    You can use threaded rods too, with double nuts as bolt head.
    There are six bolts, but I used only four.
    Juha
  2. JulianMerak
    JulianMerak Formula 3
    #2079 JulianMerak, Jan 21, 2017
    This looks excellent but did your bolts go through the lower spring pan or are they like mine, just threaded and held in with the short bolts?
  3. GrifoS2
    GrifoS2 Rookie
    May 20, 2007
    33
    Bolts do not go trough, if you look Mexico photos, lower arm is similar,
    I bought bolts to get straight factory cut, they are also stronger than cheapest threaded bar,
    I checked, my bolts are only 15 cm long, but I dismantled front suspension about 9 years ago...
    Juha
  4. JulianMerak
    Many thanks for clarifying Juha
    Julian
  5. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    1,812
    Dougal
  6. fgsavoia
    fgsavoia Karting
    Jul 2, 2011
    179
    Milano, Italy
    Francesco
    I'm one year late for these, bummer!
  7. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    #2084 thecarnut, Feb 11, 2017
    I am replacing the leather on the Ghibli since whomever did the interior last time could have done a better job. Plus with a black exterior a contrasting color for the interior would look better. Of course my wife gave me the "why are you taking a perfectly good interior apart" dirty look ....
    I was pleasantly surprised as to how straight forward everything came apart. It took me about 4 hours to do. This included taking the time to photograph everything, make notes and reconnecting some things so that the car is still usable.
    Ivan
  8. JulianMerak
    #2085 JulianMerak, Feb 27, 2017
    That looks awesome Ivan!
    Does anyone out there know how to remove the Ghibli lower front wishbone?
    Does the shaft it rotates on come out after removing that small cross head grub screw?
  9. staatsof
    91,590
    Fuggetaboutitland
    Bob
    Yeah, that looks quite usable??????????
    Go with senape. I'm just no fan of black interiors unless there's a lot of wood as well.
    That color in your Bora would be nice but probably it wasn't available for that car at the time?
  10. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,227
    Harriman, TN USA
    Michael Demyanovich
    #2087 Mexico074, Feb 27, 2017
    Hi Julian..
    Yes, after removing the set screws (cross head grub screw ?) in the lower a-arm, the
    pivot rods can come out.. Will they easily, that's the real question. Many have different
    methods of removing them.
    In the end, I ended up having to drill out the set screws. I also tried using the pivot rod nuts
    and lots of washers to turn the pivot rods out, but all I did was strip the nuts. In the end
    I sacrificed the pivot rods by spraying lubricant where the rods enter the a-arm frame
    and hitting them back and forth with a hammer and continuing to spray lubricant until
    they came out. Took quite some time, as I proceeded very carefully.
    Hope yours come out easily.. Attached is a picture of the front suspension and
    some other pieces ready to go back on my car... The new pivot rods are in the white
    envelope/bag..
  11. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    Well .... I should have been a bit more specific :)
    By usable I meant that the car can be started and driven on to the trailer as I will need to transport the Ghibli to the upholstery shop.
    For example, if the AMP meter is disconnected the car will not start as all the "switched" current runs through this gauge. As you know Maserati left many accessories "live" even when the ignition is off so one must be careful that no live wires can short out.
    I'll be using PAC 1386 Marrone for the interior, same color Frank is using on his Vignale spyder. It should look really nice with the black exterior.
    BTW: I plan to attend this year's Concorso Italiano with the Ghibli as they will be celebrating the 50th anniversary. Any other Ghibli owners going?
    Ivan
  12. staatsof
    91,590
    Fuggetaboutitland
    Bob
    My Espada is similarly disabled now due to a brake failure while waiting for my seats to be rebuilt. Hopefully my boosters haven't rotted as well. They were rebuilt a while back. To be fair both the clutch and brake masters were original. Probably due to just how friggin' difficult they are to replace.
    That amp meter is "interesting" :eek: I guess a few fires have been started that way.
    That color will look much better IMHO. Richer and sexier. I like red in black cars too.
  13. JulianMerak
    Thanks once again Mike for your help!
    I'll see if it wants to play on the weekend
  14. eogorman
    eogorman Formula Junior
    May 10, 2005
    322
    Buhl, ID
    Eugene O'Gorman
    Ivan , glad to hear you are planning to attend Concourso Italiano this year. I also plan to attend but I am not sure I will have my Ghibli ready to run by then. I had not seen that They will honor the 50 th anniversary of the Ghibli. Hope that will bring a few more out. We had a very poor turnout of vintage cars last year so we need all the help we can get.
  15. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    #2092 thecarnut, Feb 28, 2017
    Today I received this reminder from Concorso and noticed that the Ghibli anniversary is mentioned.
    We need to have a good showing of Ghiblis.
    Ivan
  16. JulianMerak
    #2093 JulianMerak, Mar 7, 2017
    Hi,
    Can anyone tell me what to undo to allow the front stub axle assembly to be separated. The part is off the car and all 3 visible nuts on the back of the assembly are now loosened but I can't see how the disc and stub axle comes off the upright. I have the 52mm knock off hubs
    Thanks for any help!!
    Julian
  17. JulianMerak
    #2094 JulianMerak, Mar 7, 2017
  18. JulianMerak
    #2095 JulianMerak, Mar 7, 2017
  19. JulianMerak
    #2096 JulianMerak, Mar 7, 2017
  20. chriskindl
    chriskindl Rookie
    Apr 2, 2010
    45
    There is no short cut regarding the brake discs.
    Unscrew the center nut first, which hold the bearings. leave the axle in place, please.
    Best,
    Marek
  21. JulianMerak
    #2098 JulianMerak, Mar 7, 2017
    Thanks Marek,
    The stub axle is off and the knock off centre comes off easily enough.
    The car is being prepared for paint so I may as well rebush and Powdercoat all the suspension when it's off the car
    Julian
  22. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,227
    Harriman, TN USA
    Michael Demyanovich
    Hello Julian...
    PM sent ....
  23. Candide
    Candide Formula 3
    Apr 6, 2017
    1,472
    Monaco
    Hello Ivan,
    Have you got maybe any pics of the rigid brake tubings that are under the dashboard on the left side pillar ? (the one that come from and to the master cylinder - and how they pass to the engine compartment and attach to the booster...)
    Thx.
