News
Maserati Ghibli (1966 - 1973)
Discussion in 'Maserati' started by miuras, Feb 27, 2007.
  1. thecarnut
    thecarnut Formula 3
    Apr 22, 2006
    2,368
    Atlanta
    The Car Nut
    I guess I will not be getting that free trip to Melbourne after all :) Looks like you have made a lot of progress.
    All four lamps should be on when high beam is activated. From your description it appears you have a H1 bulb in the high beam lamp and a H4 bulb in the low beam lamp. A H1 bulb has only one connector and gets ground through the body of the lamp. A H4 bulb has three connections; a low beam, a high beam and one for ground. Behind each of the pair of lamps you should find a wire connector. The diagram below shows how it should be connected. Using a multimeter you need to determine which of the three bulb connectors is common to both bulb filaments, this is where you connect the ground wire.
    Ivan
    MK1044 and Froggie like this.
  2. JulianMerak
    JulianMerak Formula 3
    Thanks Ivan,
    I think even I should be able to work with this. thanks again
  3. JulianMerak
    MK1044 and Nembo1777 like this.
  4. sinkman
    sinkman Karting
    Oct 28, 2010
    217
    Melbourne Australia
    Phil
    Julian the Ghibli is looking FABULOUS!
    Best Regards
    Phil
  5. JulianMerak
    Thanks Phil,
    I used Glenn to sort out my electrics who Paul thought had helped you with the Ferrari!
    Getting quite close now
    Julian
  6. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,056
    Harriman, TN USA
    Michael Demyanovich
    Looking very very good Julian!
  7. JulianMerak
    MK1044 likes this.
  8. luvcoupes
    luvcoupes Karting
    Jan 29, 2011
    171
    San Francisco
    Wheels on, lights up, ready for take-off...and a pillow just incase there's a delay.
    JulianMerak likes this.
  9. JulianMerak
    MK1044 likes this.
