Does anyone know, what the pump with the slash through it means. this is on the gauges.
You mean to say printed on one of the gauges, or a warning light icon? Low/Reserve fuel indicator is a round orange light on the fuel gauge. There is also a CC pump....Probably need more details, as in what car is this in....
I beleive there is a fuel inertia cutoff valve and it may have been triggered...this may be what you are seeing. The switch to reconnect should be located in the right hand side of the trunk near the cd changer. I would check your owner's manual...
that is what it is. I just went out and looked at my manual and it shows a gas pump with slash thru it and says it is the "Inertia switch activated warning light"
i dont have the manual and i dont have the cd changer. Can somone give me the exact location of it. Is it the one with the black nob and says off on it?
No, That is the battery switch. You need to go to the compartment on the drivers side. Even if you don't have the CD changer you still have the compartment. Just pull open the cover and towards the front you will see a round rubber button facing up, just push it down. I am keeping my manual at my desk for the rest of winter so if you have any other questions let me know.
