Maserati Indy thread | Page 6 | FerrariChat
Discussion in 'Maserati' started by ignominus, Dec 24, 2015.
  1. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    A logical conclusion, as it’s the only way it can work. The other cars I have had, including my Fulvia Zagato which uses the same Battani jack fits at a right angles to the sill, which is what confused me. Thanks for your assistance:)
  2. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Happy New Year!
    I have now completed 1000 kms in my Indy 4.2, and seek clarification in regards to the re-torquing of the cylinder head and valve clearances. In the Indy handbook this is mentioned as a service procedure at 10,000 kms, however in US literature for the later Khamsin and Bora it stipulates 1,000 kms… as the engines are from the same family what would be advisable?
  3. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    I like to retorque the heads the next day after the first warm up and then again after 500 miles. If you already put 1,000 kms go ahead and retorque the heads. I would not hurt to retorque them again after 10,000 kms. Good that you are driving the car!
    Ivan
    gto406_2 and Ferraripilot like this.
  4. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thanks for the advice, much appreciated as always.
    Mark
  5. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    I recently ordered a replacement oil pressure sender for my Indy (the type that screws into a banjo fitting held to the block by the low oil pressure switch, I believe the Bora is similar) However the new sender FAE brand is marked 0-8 which I assume is 0-8 bar, as the gauge is marked 0 - 11 bar (0-160 psi) I’m concerned this will cause the gauge to under or over state the oil pressure?
  6. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    The original sending units have not been available for a long time. The unit you have will work but the gauge reading will be too high. You could take a reading using a mechanical pressure gauge at 3,000 rpms and then compare it with the reading using the sending unit. Adding a series resistor to the sending unit would then bring the gauge reading down. It will only be accurate at 3,000 rpms but that is better than the alternative.
    Ivan
  7. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thank you Ivan, your reply and advice is much appreciated.
    Mark
  8. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    My Indy is fitted with the ZF S5- 20 5 speed manual transmission and while gear changes are smooth when warmed up, while cold it’s a little hard to shift. I’ve had success swapping to synthetic gear oil in my Lancia Fulvia, any gear oil suggestions for the Indy that may improve the quality of the shift?
    Cheers Mark
  9. Froggie
    Froggie Formula Junior
    Sep 27, 2017
    537
    Belgium
    Serge
    My Indy behaves the same.
    Not surprised however, it takes some time for all that mechanics to warm up and you have to respect it, the gearbox taking the longest time and you have then to change gears slowwwly.
    But when warm, the shifts are swift and creamy!
    I have not myself considered full synthetics for the gearbox.
    Nembo1777 and indyvignale like this.
  10. staatsof
    96,378
    Fuggetaboutitland
    Bob
    Redline MTL helped quite a bit with the ZF 5 speed in my Biturbo. Redline makes great stuff and you used to be able to call and talk to their tech guy. Now ?????????????????????????????? Like everything else.
    indyvignale likes this.
  11. Froggie
    Sep 27, 2017
    537
    Belgium
    Serge
    I also went to Redline MTL for my E-Type 3.8, a well-known tip within the E-Type community.
    That car has indeed an antique Moss gearbox with non-syncro first gear.
    In that case after a few hundred miles the behaviour of the gearbox increased substantially.
  12. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thank you, good to know that other gearboxes are the same
  13. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thanks, much appreciated!
  14. wilde
    wilde Formula Junior
    Jan 12, 2009
    261
    France
    Don't worry, ZF gearbox from period are hard to shift when cold. I never tried Redline MTL. I'll do that...
    Nembo1777 likes this.
  15. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Another cooling fan question…
    On the early Indy (4.2) there are two pusher fans mounted in front of the radiator (similar to the early Ghibli I think) There are also two ‘otter switches’ (same switches as the E type Jag) mounted one above the other on the left hand side of the radiator (drivers side on a LHD car). There are also two relays as part of th circuit.
    My actual question is regarding the correct operation of the cooling fans…
    I assume one cooling fan switches on/off when the AC is turned on/off?
    While the two ‘otter switches’ switch on both cooling fans when 90c is reached, then off at 80c?
    Is this a correct assumption as currently only one fan comes on when temp reaches 90c the other only when the AC is switched on.
    My final question is whether it’s worthwhile replacing the ‘otter switches’ with more modern Thermo switches like the ‘Coolcat’ conversion offered for Jaguars?
    Mark
  16. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    I assume the Indy is wired similarly to the Ghibli where one radiator thermo (Otter) switch controls only one fan. A quick test is to ground each Otter switch individually and verify that a fan turns on. I like to put a jumper wire between the two relays so that when either thermo switch triggers both fans turn on. Otter switches have a high mortality rate so the cool cat alternative is a more reliable solution. Maserati stopped using Otter switches on the later cars.
    Ivan
  17. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thanks Ivan, I like the ‘jumper wire’ idea to ensure both fans run.
  18. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Wheel bolt torque
    I have been unable to find the ‘torque specs’ for the wheel bolts for the Maserati Indy, any thoughts?
    Note my Indy has the 14 inch diameter ‘Borrani Dial’ wheels fitted.
    Mark
  19. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Thought I’d share some pics of an original unrestored 4.2 litre Indy (RHD Auto with power steering) that was picked up from the Maserati factory by the original owner and driven around Europe on holidays before coming to Australia. I first saw this car 25 years ago and tried to purchase it, sadly missed out, but good to see its well looked after and cherished. Image Unavailable, Please Login Image Unavailable, Please Login [ATTACH=full
  20. emsiegel13
    emsiegel13 Formula Junior
    544
    Grayslake, Illinis
    Elliot M. Siegel
    That's a great color!
  21. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Here’s another 4.2 litre Indy from my archives. Believed to be the first right hand drive Indy produced and still in the hands of the original owner Ray Gulson, who ordered it new through the importer Alec Mildren in Sydney. Ray was also a Maserati agent, and I saw this actual Indy as a kid along with other Italian exotics at his dealership, left quite an impression I guess as ultimately I ended up with my own Indy.
    Ferraripilot, JulianMerak and rob like this.
  22. indyvignale
    indyvignale Rookie
    Apr 12, 2009
    39
    Question regarding the front suspension on Indy’s and Ghibli…
    Are the upper and lower ball joints the same as those on the Jaguar MK2, S Type, 420 etc?
    I ask as the Jaguars can be fitted with the newer style upper and lower Lemforder sealed ball joints, this is of interest as the original Maserati upper ball joints require greasing via the grease nipple and the lower ball joints have shims for adjustment. I like the idea of having less maintenance and fiddling about in the future as I need to replace the upper ball joints
  23. F1tommy
    F1tommy F1 World Champ
    11,691
    Sugar Grove USA
    Tom Tanner
  24. staatsof
    96,378
    Fuggetaboutitland
    Bob
    F1tommy likes this.
  25. F1tommy
    11,691
    Sugar Grove USA
    Tom Tanner
    Maybe the guy is divorced and made his dream bachelor pad :cool: Looks like a basement.
