Maserati Khamsin help needed please | FerrariChat
Discussion in 'Maserati' started by Alex C, Aug 5, 2018.
  1. Alex C
    Alex C Rookie
    Aug 5, 2018
    2
    Alex Childs
    Hi everyone,
    I’m in the process of replacing the o rings on my Khamsin and need to find out the torque settings for the 4 inlet manifold bolts?
    Any help would be really appreciated?
    Thanks again.
    Alex Childs
  2. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    The Torque figure will be a Standard torque for the bolt size used.
    Just make sure the manifold is sitting on the 4 pins (2 on each head) and will have a small gap between the manifold and heads on each side.
    If the heads have been skimmed this gap can be lost and the manifold will sit on the head directly and the ports will be miss matched. If that's the case the manifold will need skimming to restore the gap. Sadly there is no measurement for this .25mm is enough check with no "O" rings installed.
  3. Alex C
    Alex C Rookie
    Aug 5, 2018
    2
    Alex Childs
    Excellent thank you very much that’s a great help.
