Maserati Khamsin | Page 85 | FerrariChat
Maserati Khamsin
Discussion in 'Maserati' started by Maeter, Feb 24, 2008.
  1. khamsin433
    khamsin433 Formula Junior
    Jul 16, 2009
    291
    Birmingham, UK
    Balbir
    Hi Graeme,
    The sprocket is not on all the way as the shaft to drive the pump fits into it (can be seen in your picture). When you say that it's an interference fit, I take it that the end of the crankshaft is splined and that the sprocket slides (he laughs) onto these splines?
    McGraths do not have a puller available and offered to do the job for around £120+VAT etc. But the issue is that they are busy until sometime well into October.
    Any pics of the crank end would be appreciated if you took any when doing your car.
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I don't have the car here, but need info on make & type of compressor; a source for parts would be helpful too. (front bearing)
    Thanks,
    Jack.
  3. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Nobody?
  4. Nembo1777
    Nembo1777 F1 World Champ
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Jack I can't let you drown so in case MIE or BillMcGraths are very busy (which indeed they are at the moment) here is a contact: ask Marcello candini at Candini's in Modena, he can be emailed in English and he will either know or get the response from his father.
    [email protected]
    best regards,
    Marc
  5. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Thanks Marc, I shot them a mail in my best Italian; hope they can decipher it!
    Somehow I think it is of the same type as used in my 308, which is, I think, from Borletti, but before ordering parts I'd rather be sure. Difficult to order parts for a car that's not with me, and a compressor that is yet at another address. Wish I had a parts manual.
  6. Nembo1777
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Well I seem to recall it is a York ac device but not sure. repro parts manuals can be bought easily and cheaply via MIE or Ebay.
    Good luck!
    MS
  7. hensj2
    hensj2 Rookie
    Aug 17, 2009
    14
    Lund, Sweden
    Henrik Sjökvist
    York originally. Still made today by another company and installed in Volvo front loaders, so should be no problem to get hold of spare parts.
  8. sunburn
    sunburn Formula Junior
    Nov 2, 2003
    694
    Dawsonville, GA
    Rick R.
    #2108 sunburn, Sep 22, 2010
    Jack,
    I've attached a couple of pages from my Khamsin parts manual. Hope it helps.
    Rick . . . .
  9. Doug R
    Doug R Karting
    Oct 11, 2005
    208
    Yellow Springs Ohio
    My 75 had a Borletti, now replaced with a York. MIE has a pallet of them.
  10. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Thanks Gentlemen!
    I shouldn't have a problem getting spares locally even (clutch/pulley assy and bearing) if it's York, but if Borletti it'll be a different story. The head cap seemed ribbed on this compressor, while the York's is flat. I'll see if I can organise a pic of it.
  11. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    #2111 f308jack, Sep 23, 2010
    Pic of the compressor (on the right)
    It appears from the drawing in the partscatalogue that the York head is flat, whereas the head on this compressor appears to have some ribs in it.
    If anyone can positively identify it, I'd be most grateful!
    Jack.
  12. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Burradoo... Actually
    Graeme
    #2112 au-yt, Sep 24, 2010
    Hi Jack
    The Aircon compressor is a York. common to early Mercs etc of the same era. The comp is the small capacity version. and I believe you can still buy them new.
    I have a freind whos fitted a different type and all he was have the clutch assemply drilled to take the waterpump drive and make a bolt up adaptor that aligned the center lines.
    Find an Aircon overhaul place and tke the York they will have a pump to suit your needs.
    Cheers
    Graeme
  13. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    9,025
  14. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    Hi Walter
    I will put on my watch list to see how it goes, some one needs to grab this as they are reasonably rare.
    I spent a year putting a set togther like this including a hand written quote for a car sold in the US.
    They are excellent reference for restoration especially when putting trin back in and the location of screws.
    Best Regards
    Graeme
  15. Nembo1777
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    #2115 Nembo1777, Oct 2, 2010
    Hello all:
    Jack: just received this email from a Khamsin connoisseur regarding your question: FYI.
    Hi Marc,
    York compressors are available in Europe "off th shelf" and you can order them
    from the Hella catalogue (for whatever reason).
    On the matter of Walter's brochure and press kit yes grab it: a good buy!
    Here are two photos: an unknown Japanese Khamsin repainted yellow, just found this recently, no idea about chassis number, tried contacting the Japanese club once but got nowhere so: if anyone in Japan is looking at this I would very much appreciate help in tracking down the 31 cars (if memory serves right don't have time to look it up now) sold there and curious to know which one this is: domo arigato itashimass:)
    The second photo is not the same car: this is AM120US1160 which I found earlier this year in rural Illinois and which was sold by Ivan Ruiz in Atlanta to a German enthusiast who just informed me that the car has arrived in Germany and he will start the full restoration very soon: he seems very serious about it and is an engineer so viel gluck A.!
    best regards,
    Marc
  16. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    Great colour Shame they painted the bumpers the same colour it looses some of the detail.
    Cheers
    Graeme
  17. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    9,025
    #2117 wbaeumer, Oct 11, 2010
  18. Nembo1777
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Yep!
    Great find!
    Thanks for posting.
    The only other ad I ever saw with a Khamsin is the one for the ski rack which I posted here before.
    Graeme:
    Yes several cars have had the bumpers painted in body color and it just is not correct.
    best regards,
    Marc
  19. dougieboxer
    dougieboxer Karting
    Mar 23, 2008
    86
    Doug
    Hi Marc
    Been 'out of the loop' for a few weeks so just noticed this picture! It's definitely my car, and I'd like to say I was responsible for the photoshoot but it seems the bodyshop have been moonlighting behind my back. Mind you, I fully support their behaviour and know they would have taken good care of the car. I'll just request they get her back in the car when it's finished, and make sure she's not so over dressed!!
    Doug
  20. Nembo1777
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    #2120 Nembo1777, Oct 12, 2010
    Hello Doug!
    Hah! I am very relieved as I was worried that I had offended you by posting that photo and had visions of a bodyshop employee fired etc etc:)!
    Not so overdressed LOL excellent:)
    I guess she won't be needing this then?! As I said you find all sorts of things on the net!
    best regards,
    Marc
  21. khamsin433
    Jul 16, 2009
    291
    Birmingham, UK
    Balbir
    Just a general question to put out there as I'm having the engine rebuilt I was wondering what you guys did in terms of adding fuel additives to unleaded petrol?
    My car I know has been run for some time on just unleaded fuel. But I seem to recall some think that an additive is needed to replace the lead and those that use the 95/98 ron neat.
    I ask as during the strip down 2 of the exhaust guides werre found to be damaged, could be just down to wear but as it's apart I just wanted to make sure I do all that is needed.
    Any thoughts you guys may have would be very welcome.
    Bal
  22. staatsof
    96,328
    Fuggetaboutitland
    Bob
    Ask your engine builder to use the approriate valve seat material. He probably will anyway. There's no reason then to use a lead addititve.
    Bob S.
  23. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    Hi Bal
    I was probably under the miss conception that the valave seat material was suitable for Unleaded fuel.
    However I know that early pre Khamsin Masearti engines were not suitable.
    The US went to Unleaded in 68 so in "theory" cars sold in the US would have the harder seats.
    I would love some clarification on this.
    Regards
    Graeme
  24. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
  25. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    9,025
    Hi Graeme,
    thanks!
    The price is 100% OK for me and the kit goes to a Maserati enthusiast from Switzerland.
    Ciao!
    Walter
