Maserati Mistral thread | Page 5 | FerrariChat
Discussion in 'Maserati' started by Serenissma, Jul 10, 2008.
  1. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    Thanks, Ivan.
    Those are great links. I would add that some years back I had a good number of engine brackets, fuel rails, and so on redone as per factory finish in yellow zinc chromate, only to find it to be a sacrificial metal with much of it disipated after a few years during the course of weekly driving.
    Typically, if not always, these cadmium type [true cadmium not used commercially AFAIK] parts are first plated in nickel [Ni] then plated with yellow zinc chromate at the factory. I believe Caswell has nickel plating kits as well. Doing a multiple plate may not yield a much improved look over doing a single plating with zinc as you did.
    Long story short, if you wish to preserve all the hard work prior to installing, powder coating is the ultimate final hard finish to apply. It is an easy process for a DIYer that can be done at home. Ivan, in your case, you may consider spraying those parts in situ with a clear coat for that extra lasting protection.
    Just Sayin! :)
    Ciao,
    George
  2. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    I agree. As a last step the parts are sprayed with a clear coat.
    Ivan
  3. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    #103 thecarnut, Nov 13, 2014
    A prior "mechanic" had his hands on the wiring and much of my time has been spent with a multimeter identifying and labeling each wire ... plus undoing some of his "fine" handiwork. Luckily the Mistral dash is not too difficult to remove.
    Ivan
  4. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Hunt. Bch/Palm Dsrt/Virginia
    Jim Crawford
    Anyone know if #1688 has survived? I owned it in the "80s. Would love to a pic of it today
  5. Serenissma
    Serenissma Formula 3
    Apr 12, 2008
    1,083
    Sweden
    Magnus Andersson
  6. Serenissma
    Apr 12, 2008
    1,083
    Sweden
    Magnus Andersson
    The blue from norway
  7. thecarnut
    thecarnut F1 Rookie
    3,274
    Atlanta
    The Car Nut
    #107 thecarnut, Dec 7, 2014
  8. jonack
    jonack Formula Junior
    Jul 3, 2007
    291
    Berkeley, California
    J. Clark
    Great shots of one of my favorite cars!
  9. lavaux
    lavaux Karting
    Jul 18, 2009
    124
    Cully, Switzerland
    Wilfried Vogel
    Hi Alex and Alain,
    I would like to add something to the heatshield discussion. Generally a shield is placed between a heat source and a part which you want to protect from that heatsource.
    The heatsource will transmit its heat in two ways to the part that needs protection:
    - by heating the surrounding air, which then will heat up the part.
    - by radiating in the infrared in all directions. The part will receive a fraction of this radiation and will heat up.
    If you place a heatshield between the heatsource and the part, the shield will most probably stop the circulation of air between the source and the part.
    If the heatshield is made of a nice, brilliant sheet of aluminium, more than 90% of the infrared radiation is reflected back to the heatsource. The aluminiumsheet itself stays rather cool. The aluminiumsheet beeing rather cool and being also brilliant on the rear side, it will emit practically no heat to the part.
    Conclusion: Painting the sheet in black is the best way to make the sheet ineffective.
    The best heatsheet is brilliant aluminium without any insulating stuff put on either side.
    If you can stand a non-original brilliant aluminium sheet, you will have the best!
    (I know, most manufacurers want to paint everything black, like the chassis, but it is wrong!)
    Wilfried
  10. kc023515
    kc023515 Formula Junior
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    #110 kc023515, Dec 27, 2014
  11. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    #111 Ursa Major, Dec 30, 2014
  12. Quattroporte3
    Quattroporte3 Formula 3
    Nov 13, 2010
    1,060
    Nice job,
    looks like you're making pretty good progress.
    Looking forward to seeing it all back together and on the road!
  13. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    Hope to have it all finished and on Norwegian plates late spring. Time is against me as this is just a hobby...!
  14. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,293
    Harriman, TN USA
    Michael Demyanovich
    Looks very, very nice!!!
    What color will the interior be?
  15. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    #115 Ursa Major, Dec 30, 2014
    The interior will be it's original Senape. This has already returned reupholstered in new leather.
    In January I am expecting the engine, gear box, rear axel and steering rack back from the mechanics. My job will be to complete the puzzle. Will be nice as it's been 1,5 years since I saw the car complete... 2015 will hopefully be a nice season.
  16. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    I should probably make a restoration thread in this section as I have tons of photos from the process since I purchased the car as a running project in May 2013. I seem to have some sort of limitation on how many pictures I may upload - does anyone have the cure for that?
    By the way; I hope to drive the car from Norway to the South of France in September for the International Rally held by the French club. Hope to see some of you there!
  17. rentsch1961
    rentsch1961 Karting
    Oct 22, 2012
    83
    Geneva, Switzerland
    Alain RENTSCH
    Hi Alex,
    The color combination of your car will look great.
    The time is against me too. I am still scraping the floors and underbody and I will not be ready for the MIR 2015.
    Please post more pictures on the Lazzaroni forum. I am anxious to see the rebuilding process.
    Good luck, Alain.
  18. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,293
    Harriman, TN USA
    Michael Demyanovich
    Hi Alex...
    I agree with Alain.. The color combination will look superb!!!
    To post more pictures here, you may have to upgrade your membership level.
    Ivan Ruiz advised me of this, and I have had no problems since.. All of us Mistral
    owners are very keen to follow both your and Alain's progress!
    What is the Lazzaroni forum?? If this is something we fellow Mistral owners
    should know about, please forward the link and other pertinent information..
    It is good to see both your and Alain's Mistrals coming back to life in such great
    condition!!! Gives the rest of us hope on ours someday...
  19. rentsch1961
    rentsch1961 Karting
    Oct 22, 2012
    83
    Geneva, Switzerland
    Alain RENTSCH
    #119 rentsch1961, Jan 1, 2015
    Happy new year to you all and a lot of pleasure restoring and driving.
    Thanks Mike for your kind words.
    The progress on the Mistral is very slow since 2-3 monthes, because the scraping work is very unpleasant (as you all know...)
    When it's finished and I begin to weld and paint, I will post "before and after" pictures of the work again."
    But, sincerely, there is another factor that slows the work on the Mistral down. A '68 Fiat Dino 2000 Coupe is now in the garage too.
    I saw it in France in December and couldn't resist to buy it. It's a 2 owner's, never restored car. Even the "Giallo Positano"paint is original.
    I have always liked the look of this car designed by Candini and Giugiaro. The Dino engine's sound is faboulus. It only needs a good tune up of the engine to be enjoyed as is.
    Alain.
  20. Shamrock
    Shamrock Karting
    Nov 18, 2012
    84
    Svezia
    Stefan
    Your car looks great Alain, it deserves its own thread. The Dino is a neat little GT. Agree on the sound. And a perfect color for it.
    /Stefan
  21. gerardogras
    gerardogras Rookie
    Nov 22, 2007
    8
    hello mistral folks,
    i own 2 x mistral and found enrico's maserati pages very useful.
    purtroppo he shut down his classic parts page because of fraud mails.
    is there any other place for mistral parts?
    thanks
    frank
  22. Ursa Major
    Ursa Major Karting
    Feb 25, 2011
    162
    Norway
    I also miss that parts page. My tip would be just to leave a request here in this thread id there's something you can't find through the regular places, like MIE or eBay. I have also sourced parts through leboncoin.fr and subito.it. Happily my car was complete, so only service parts needed. In addition you can of course find parts at specialist, like Bill McGrath or like for the Lucas at powerprops.com.
    What are you looking for?
  23. mamamia
    mamamia Karting
    Dec 14, 2010
    214
    England
    Henry Jameson
    I noticed that Enrico has resumed his classic parts pages.
  24. gerardogras
    gerardogras Rookie
    Nov 22, 2007
    8
    thank you for the replies.
    enrico's classic page is again.
    my mistral is still missing original steering wheel, gas door chrome surround, new engine balancer, chrome vacuum pipe lucas injection, dash center switches.
    does anybody have experience with harrington group bumbers?
  25. Mexico074
    Mexico074 Formula 3
    Aug 14, 2008
    1,293
    Harriman, TN USA
    Michael Demyanovich
    Hello gerardogras...
    What year is your Mistral(s)? Do you have a picture of the steering wheel you need?
    I think I saw the gas door chrome surround for sale on e-bay not that long ago.. The
    dash center switches could be a little bit more difficult to find.. I don't think they are
    the same as the rocker switches found in the later cars....
