Hi, i need your help, the car did not have doors, I bought a couple but I think I need more pieces since the glass does not go up well. can you help me?... regards Image Unavailable, Please Login
Hello Jhoniks, Nice to see that you are working on a Sebring. Have you seen our FB group "Maserati Sebring"? Just a small suggestion: Don´t create a new thread everytime you want to communicate. It´s better to "put all your eggs in the same basket" so to speak. I can assure you that you will create more interest that way. Ciao, Jan
Hi Jhoniks, My 65 Sebring has a different window regulator than the one you have pictured, but I have seen a variety of regulators used on different cars. What do you mean by "the window does not go up well" Is it slipping as it winds up? If so the cast gears used on some of the window regulators tend to lose teeth, which will cause slippage. Not all of the regulators used cast gears, some had steel. (not 100% on this but it is what I have found over the past three years. If it is just difficult to move up and down, it may be the window seals and runner felts are so dried out that is impeding the window from moving properly. Joe
+ One trillion: surely anybody can understand that?! Please stop starting new threads every three minute it is very annoying and the main reason why you have had so very very few replies. you don't seem to realize that it is a rude way to operate, worse than interrupting a comversation actually like jumping on the table. Do ONE thread called Sebring restoration questions and stick to it FOREVER. please stop POLLUTING the Maserati forum with your mini threads every three seconds, thank you. MS
Hello, I have already advanced a little and I have found that the gears are in good condition, I have changed the filaments, the window goes up without much problem, I have a detail that does not close completely, the glass is misaligned (it is tilted a bit). I appreciate your enthusiastic comments, especially yours Nembo1777, thank you for reading me even with the millions of threads that I created. I will regulate this. Excellent day. Jhoniks
