my sebring series 2 carburetted has no brake booster, has a mounted brake booster? where has it been mounted? ... Can someone help me with an image? regards jonathan
My 1965 has two boosters. They are both located in the drivers side front fender well. The servo’s are girling, similar to the one used in the Austin-Healey BJ8 with the flat bolted on cover. I do not have. Pictures handy at the moment. Joe
Johnathan, Here are a few photos of the brake boosters Joe Image Unavailable, Please Login Image Unavailable, Please Login
thank you Joe, ..I have tried to find the place that you indicate me, only that I do not have an adequate space to place it, it is very reduced. Can you help me with an image of how you had it mounted?
When we put them back in in a few weeks, I will take a picture. They are staggered on a bracket and it is a tight fit.
Here are some photos of the brake boosters mounted. Drivers side front half of fender well. Joe Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
That is the drivers side forward part of the fender. (Left Hand Drive Car). Also on one of your other posts you asked about the horns. On the last photo, you will see a bracket protruding out wit two holes (one has a bolt in it) that Is where the compressor for the Air horns is mounted. Joe
Yes, i view, I just have problems with the horn button, how is it connected? Image Unavailable, Please Login
It may depend on the car and the horn set-up. My car has a directional stalk and the horn is actuated by pushing in on the end of that stalk. It appears to be the original set-up, but I am not 100% sure. There is a horn button on the steering wheel center, but that is not connected.. I believe some cars had a contactor that rubbed against the steering shaft to allow the wheel to be turned and still maintain electoral contact with the horn button. I will have to look further into the this as the column is out of the car and I am starting to work on its restoration now.
this the claxon bottom , this style has two buttons, one of them the emblem of maserati and the other around, but I do not know what works or what activates each one. besides that I also have the thrust actuator on the directional lever. Image Unavailable, Please Login Image Unavailable, Please Login
It most likely depends on how your car was set-up from the factory. You have two connections on the button one for the center button, and one for the outer ring. I would assume you would then need two wires through the center of the column to make the connections for the various horns. Your car may not have had the town and country horn option?? MY car only has air horns. Maybe someone ese on the forum has a better answer. Joe
thank you for your comments, If I have both air and speaker, just do not know where each one connects, I keep looking though I have not found much information about it. Do you know if these cars had a seat belt? can share information by email? ...
You can help me with measures to place the emblems of vignale and the front of the car. Image Unavailable, Please Login Image Unavailable, Please Login
