Maseratti V8 block = Ferrari block | FerrariChat
Discussion in 'Technical Q&A' started by 11506apollo, May 5, 2010.
  1. 11506apollo
    11506apollo F1 Rookie
    2,689
    Tx Co Ca
    Do you guys know if the 4.2 L Maseratti V8 block is built by Ferrari? Anything different if it is, from a "Ferrari" car with it?
    Thanks.
  2. Rifledriver
    36,921
    Some parts interchangeability but lots of differences too.
    I believe all the castings and forgings are done by Ferrari. I saw the cranks being made.
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,649
    South East
    Jimmie
    All units assembled at Ferrari so on the factory tour the main color in that department is blue not red cam covers
    I'm sure full technical details eg compression ratio & power output differences have been posted here before
  4. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Blue cam covers for the 4.2 (granturismo), Red cam overs for the 4.7 (granturismo S) ;)
  5. TheMayor
    105,475
    Vegas baby
    #5 TheMayor, May 6, 2010
    In the Maser, it's not a flat plane crank like the Ferrari. But, it's a wonderful engine. They are definately not the same engine but they have similarities and they are built on the same assembly line.
    I've had mine going on 8 years and it still thrills.
  6. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    BTW the 4.2 and 4.7 are not dry sump as Ferrari's engine but regural oil system lubrification. That makes a huge difference. I believe that ony the basic engine molded structure is identical but that's it. The entire engine equipment is totaly different between Ferrari and Maserati.
  7. Fred2
    Fred2 F1 World Champ
    18,117
    nj
    The 4.2 in the 4200 coupe series is a dry sump engine.
    They went to the wet sump with the later engines as used in the Granturismo.
  8. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Correct me if Im wrong, but the masserati 4.2 engine is chain driven vs belts on the 360. I think ferrari test the chains on the cambiocorsa and then use the chains on the 430.
  9. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Sorry!
    The quetion was about the block and not about chains!
  10. TheMayor
    105,475
    Vegas baby
    #10 TheMayor, May 9, 2010
    The 4.2 Maserati block is related to the F430 block, not the 360. Both the 4.2 Maser and F430 are chain driven.
    But, they are not the same engine.
    And, the 4.2 is a dry sump motor as is the F430.
