Mass Air Flow Meter Question | FerrariChat
Discussion in '360/430' started by delta2210, Nov 15, 2010.
  1. delta2210
    delta2210 Karting
    Aug 15, 2009
    128
    Las Vegas
    Jason
    I am still having problems with rough idling on cold starts. Was not a problem during the summer so much, but is real problem now that it is cold in Vegas. I cleaned my MAFs again with no resolution of the problem. I think it may be an air temperature issue. Evidently, there is a sensor in the MAFs that detects the air intake temperature.
    What happens if I try to start the car with the MAFs disconnected?
    I also found the part number for the MAFs, which is Fooc2g2030. That is F oh oh, no f zero zero. I found a place in the UK that sells them. Ricambi sells them for $300 each. UK place sells them for $150 each. Anybody else have a source for these?
  2. 900ssDuke
    900ssDuke Karting
    Sep 12, 2007
    214
    I had to replace one here in the UK, the price was nearer your $300 than $150 from an authorused F dealer. Lots of rough idling and a check light before I replaced it.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    majority of 360 owners all have the same concern,i have not herd of anyone doing a 100% fix for this concern,please keep us posted.
  4. speedy1wrc
    speedy1wrc Rookie
    Sep 29, 2010
    49
    Buffalo, NY
    Mark Wetzel
    On all Bosch Motoronic systems unless specifically altered by the manufacturer you will experience a fallback if you unplug the MAF. AFAIK this includes the Me7.3. It will default to a preprogrammed map which will yield an ignition retard of between 6-8 deg and an overall enrichment of varying degrees depending on if other system sensors are failed or not. If your IAT is also faulty you will see the same result. However if either were seriously faulty you should also expect a CEL.
    Let me pause for a moment to chuckle as I live in Buffalo and I had to laugh when you said it was cold in Vegas. LOL!
    If you have the tools, I'd find the measuring block for each IAT and plot them as a function of temperature. Sorry, I don't know them off the top of my head. For grins I'd do the same for the MAF, although I would suspect the IAT before the MAF actually. The temp of the MAF is regualted by a stable current supply and that should be independent of ambuient air temperature. The IAT output however is directly coupled to ambient air temp.
    Start there before replacing the MAF's.
  5. speedy1wrc
    speedy1wrc Rookie
    Sep 29, 2010
    49
    Buffalo, NY
    Mark Wetzel
    Oh and I was also just thinking along the lines of temperature. You should also check the coolant termp sensor. Although it should also throw a CEL on "new" Motronic's. I don't have a schematic handy, but it also will cause rough idling especially in the margin temperature area. Whereas if it's really cold (not Veags) or really hot (like Vegas) then it behaves normally. But in the area where the switch thinks it should or might open, then it gets ragged with some of the built in hysteresis inherent in them. The same applies to the IAT.
    Sorry for rambling.
    Hope this helps.
  6. lndshrk
    lndshrk Formula Junior
    Nov 7, 2003
    753
    SLC, Utah
    Jim Conforti
    Rather than just replacing parts, it is very easy to hook a diagnostic scanner - even a basic OBD-II scanner to your car and see if the air temperature that is read from the MAF via the DME matches (within some reasonable variation) "reality".
    You could also get a similar car and warm them both up and see the reading for air mass at idle to see if the MAFs are reading the air properly.
    Cold start problems sound like programming/calibration issues as much as defective parts.
    Jim
  7. delta2210
    delta2210 Karting
    Aug 15, 2009
    128
    Las Vegas
    Jason
    A friend of mine just bought a 2008 430 spider and he has the same problem. One would think that Ferrari would have solved this problem in nine years.
    I will probably have to have the shop check the IAT temperature curve. My technical skills and tools may not be up to that task. I do have an OBD2 to check some of the other measurements.
    I also talked to Fabspeed and they said it might be the air box covers, in that the 360 air boxes are very poorly designed. It is not supposed to be windy here today, I may crank the car up with the air boxes off to see if improved air flow helps the situation. If so, I may drop the 1095.00 on the Fabspeed covers.
    Temps here in Vegas have been in the low 40's at night. It is not really hot or cold, so that may be an "in between" temp, where the sensors do not know what to do.
    I am going to call the dealership and have them see what they find on my friend's car when they start it. It is at the shop right now for a battery issue.
  8. delta2210
    delta2210 Karting
    Aug 15, 2009
    128
    Las Vegas
    Jason
    started it this morning with the air box covers off, no change. Though the design of those things is really bad.
    It is like they took a scroll saw and cut a hole in the box and shoved the intake tube into it. Very non-elegant and flow-restricting. Probably am going to buy the Fabspeed covers anyways.
  9. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    very well could be that the maf sensors are damaged due to oil contaminating the wire. this usually happens when someone overfills the dry sump and oil vapors get drawn in the by intake manifold and then circulate through the air.
    If you know of anyone around you that you could swap maf sensors without buying new ones to see if the problem still occurs would be the easiest and cheapest way to isolate your problem.
  10. blkdiablo33
    Jul 12, 2004
    4,454
    i have swapped mine with other mafs and same thing .i was told it could be a software concern there might be a reflash,im thinking its all fuel related because when i crank for a few seconds turn car off than restart it starts up perfect.
  11. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #12 voicey, Nov 16, 2010
  12. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Delta, did you check that the DME is in open loop at startup? This can be easily monitored with any kind of OBD diagnostic tool. To get the cats hot faster, the DME should be in open loop and not closed loop. I was thinking also about a failure of the header air injection system but the F430 doesn't have it (the Scud and 360 does have it though).
  13. delta2210
    delta2210 Karting
    Aug 15, 2009
    128
    Las Vegas
    Jason
    I just dropped the car off at the dealer. They are going to start it tomorrow with the SD2 hooked up and see what happens. They suspect the IAT in the MAF. They said those units are good for maybe one or two cleanings then they deteriorate in performance. May not get any codes, but they just don't work right. They have an extra pair and will see what happens when they swap them.
    My car has been dying on the first start. Rumbles/gurgles on second. Then catches fine on third. Drives fine. Just irritating.
    They also said it may be the ECU need a software update or something. My car is a 1999, so updating the software can be dicey as these cars do not have all the emission parts the later models have. New software looks for parts that are not there = problems.
    Will update when have more info.
