Master Class - Steak Do's & Don'ts | FerrariChat
Discussion in 'Drink, Smoke, and Fine Dining' started by rob lay, Oct 5, 2024.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,345
    Southlake, TX
    Rob Lay
    Watched this video and learned some things although I already do a really good steak. I have taken notes so you don't have to watch. :D
    Do's
    • High quality meats.
    • Let pan heat up all the way before putting steak on.
    • Use a good high temp oil, like vegetable oil.
    • Sit steak room temp before grilling.
    • Pat steak dry before grilling.
    • Salt & pepper before grilling.
    • Filets and leaner steaks rare to medium rare.
    • Fattier steaks at least medium as fat needs to render and it will be more tender than rare.
    • Let steak sit to capture juices, if it drains out when cutting you are losing some of the juicy.
    • Don't flip steak too much, it needs to develop a crust.
    • Extra flavor only at end baste in butter and other seasonings.
    • No difference to pepper before or after grilling, the pepper doesn't "bitter".
    • Cast iron the best for steaks.
    • Pull steak 3-5 degrees below your target temp as it will come up during rest.
    • Don't rely on steak check by pushing, only a temp check is accurate as different steaks have different densities.
    • Cut steak against grain to help break down fibers to make more tender vs. doing all the work with your teeth.
    Don'ts
    • No old school "Italian Dressing" marinating, it "cooks" the steak grey in marinate and makes sour.
    • No wine reduction basting UNLESS mix half with a chicken/beef stock and tons of other seasonings. Straight red wine reduction very sour.
    • No Olive Oil or Butter early as it burns.
    SAFE4NOW, tomc and INRange like this.
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Great guidelines. Only things I would add are - if you're grilling, don't be lifting the grill lid every minute or two, and set up a two zone fire.
    Flare ups leads to charred steak. Go online and get a rough estimate of how long your steak should take given its type and thickness, and your cooking method, and use a timer to keep track. Then you can switch between hot and cooler side of a two zone fire, to get it perfectly done to your desired temp.
    T
    rob lay likes this.
  3. rob lay
    Dec 1, 2000
    63,345
    Southlake, TX
    Rob Lay
    I do like the charred though as personal taste, Mike Weaver calls that Pittsburg Style or maybe Black & Blue is more common. I get it by splashing oil on fire at the very end for a purpose flare up.
    TifosiConch and tomc like this.
  4. rob lay
    Dec 1, 2000
    63,345
    Southlake, TX
    Rob Lay
    #4 rob lay, Oct 6, 2024
    I'm going to try and organize everything in exact steps, correct me if you see anything.
    • buy the highest qualify filet
    • let sit to room temperature
    • pat steak dry
    • get grill up to high temp
    • if pan cast iron and high temp oil
    • salt & pepper steak
    • place on grill and don't flip until one side is done
    • towards end optional baste butter+
    • towards end optional sear with oil flash fire
    • pull off temp check 120
    • let steak sit 5 minutes
    GatorFL and darth550 like this.
  5. darth550
    Jul 14, 2003
    60,972
    In front of you
    BCHC
    Sometimes I start the fire by putting bacon on the grill, then use it as a garnish.
    rob lay likes this.
  6. donv
    donv Two Time F1 World Champ
    25,789
    Portland, Oregon
    Don
    High quality beef is the most important thing. From then on, unless you burn it, it's hard to go wrong.
    rob lay and darth550 like this.
  7. Eric R
    Eric R F1 Veteran
    6,746
    The Woodlands, Tx
    Eric R.
    I have never cooked a steak on the stove. I understand why lots of restaurants do. I love my infrared burner on the grill.
    rob lay likes this.
  8. rob lay
    Dec 1, 2000
    63,345
    Southlake, TX
    Rob Lay
    I cook steaks as much for the experience as the results. Have a drink while getting the Big Green Egg going etc. However, it would be much easier if I just turned the stove top on high and might get better results as the guy in video. The Egg is better for low and slow BBQ, but takes me an hour of work to get it super hot for steaks high and fast. :D
    TifosiConch and Eric R like this.
  9. donv
    25,789
    Portland, Oregon
    Don
    Sometimes the stove is all you have, or it's cold and wet outside...
  10. Eric R
    Eric R F1 Veteran
    6,746
    The Woodlands, Tx
    Eric R.
    Using the infrared burner, I can typically get steaks done in a 6-8min window. Watching them tilt the pans to braise with butter would take some time in my mind since it's not a complete contact patch on burner. Then you have those places that use hi temp broilers too. Those are quick.
    rob lay likes this.
  11. Eric R
    Eric R F1 Veteran
    6,746
    The Woodlands, Tx
    Eric R.
    I have 650sf of covered living space so I do not have to contend with weather so much. There was a time when I did though. Was.
