Master cylinder shims | FerrariChat
Discussion in '206/246' started by possum, Aug 2, 2014.
  1. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    Is there any where I could get some already made up shims to go between master cylinder and servo unit?
  2. shross
    shross Karting
    Sep 11, 2005
    162
    Calgary, Alberta
    No,
    You need to make it. Start with some brass stock, try the diameter I suggested and then use a Dremel or something similar to shape it.
  3. dinogts
    dinogts Formula 3
    [quotediameter Iss;143287889]No,
    You need to make it. Start with some brass stock, try the diameter I suggested and then use a Dremel or something similar to shape it.[/quote]
    What is this post about? Where's the starter thread? What does this have anything to do with Dinos?
    What "diameter I suggested . . . ?"
    Was this new thread intended for another section of CHAT?
  4. possum
    Sep 27, 2008
    307
    australia
    johnno
    I have a push rod problem with the master cylinder it is to long with no adjustment I tracked shross down via the internet as there was no reference in the 246 section I read his thread and made contact he suggested shims and I was asking if there might be off the shelf shims that would do the job instead of making one. Hope this answers your questions Regards JohnnoQuote:
  5. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Possum can you not just shorten the push rod a few thou at a time till you get it right
  6. possum
    Sep 27, 2008
    307
    australia
    johnno
    Howard, it has a dome nut which is tightened down on the rod,it was mentioned in my search drilling down the tube which the rod slides into and removing a couple of thou that way I will post some pics to better explain.If you put in brake servo rod adjustment into google you will see how prevalent this is usually after m/c has been rebuilt. Cheers.
  7. possum
    Sep 27, 2008
    307
    australia
    johnno
    #7 possum, Aug 7, 2014
    The more you persevere I believe the more you learn,can't down load pics from my phone for some reason so will try and explain.My problem is the length of the push rod is to long and should be adjustable couldn't budge the dome nut on the end of the rod so that's when I went down the shims path,I decided to have one more go of getting the nut off so I clamped the dome nut in the vice and placed the vice grips around the outer tube(the outer tube protrudes out of the servo with the dome nut on the end of it which actuates the M/C when you apply the brake).I started turning the grips Im sure some of you know what happens next,yes there is a threaded ADJUSTABLE rod inside the outer rod hence the term adjustable,have been able to shorten the length by winding it in,once I'm happy with the adjustment it can go back together.Once I sort out the phone problem I'll post some pics. Cheers
  8. possum
    Sep 27, 2008
    307
    australia
    johnno
    #8 possum, Aug 8, 2014
