max oil temperature? | FerrariChat
Discussion in 'Technical Q&A' started by st@ven, Jun 18, 2009.
  1. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,302
    Netherlands
    Steven
    Despite efforts to find the answer on this board or, for that matter, anywere else on the internet i've been looking for info in the maximum allowed oil temperature in a 328?
    my situation ( I guess quite normal)
    Normally when driving the oil temperature will reach about 190F
    When driving fast on the autobahn temperature will only slightly increase to 200F (and watertemp actually drop)
    However, when tracking at high revs the temperature tends to go beyond 250F, esspecially when ambient temperature go to +80F
    250F for me is some kinds of mental barrier but i do like to know what really is allowed (continuesly) in this engine
    For the record, i use Mobil1 0W40. full synthetic
    Any thoughts or experiences?
  2. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    The old school of air-cooled Porsche was that the max upper limit was about 285F. If it ever went to 300, then sell it if it still runs.
  3. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    250 on oil temp is a tad high for me. I would check oil fans if equipped. Make sure they are operating. I barely hit 200 degrees in my Testarossa on the hottest days.. Maybe 210 (then fans kick on).
    Robbie
  4. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    You are right about the Testarossa - never do I see over 200 oil, nor over about 195 on the coolant. Magnificent cooling system.
    And of course I live in Texas.
  5. Steve Magnusson
    26,606
    See Section 3, "oil pressure and temperature" in your OM -- gives 266 deg F (130 deg C) as the absolute maximum limit.
  6. Rifledriver
    36,821
    That was for oils in use at the time. Modern oils can tolerate much more. 360's regularly see around 300 on track days. I have been told directly by several top grade oil companies that 320 and for some 340 is OK.
  7. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The oil temp red line on the Enzo/P 4/5 is very high. On the track in Bahrain we saw 320+ for hours without issue.
  8. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,302
    Netherlands
    Steven
    That's my point too, I think the modern stuff like my mobil1 can do much more. But i do wonder if all parts of the 328 engine are up against that. I do think in general they should withstand much more but how about oil lines to the cooler, or some seals?
    Not to pinpoint you Brian but what do you think is allowed to maintain as maximum value for continuess use (lets say a full day of tracking )
  9. Steve Magnusson
    26,606
    Sure, but the OP was getting nervous at 250 deg F (so he had some headroom even at the "old" spec). But, I'd also say the ~320 deg F number that you guys are using as an example has an implied reduced service interval -- otherwise, you wouldn't do any oil changes for "track days" ;)
  10. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    This is where the synthetics take care of you - much slower breakdown during high temperatures.
    Chevrolet was so cynical about this that the last-year Corvette C4 LT-4 330 h.p. engines did not even come with an oil cooler - they just specified Mobil One for this very reason.
  11. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    On track days, my oil would stay at around 250-260 while driving. Using Redline engine oil
  12. Rifledriver
    36,821
    No question that it should be changed when the limit is pushed but I suppose that can be said about anything. We have to remember that the gauges and books were made in a different time with different information. Point is if OK pressure is maintained I wouldn't pay much attention until the 290 or 300 line is crossed....with quality oil of course.
  13. Rifledriver
    36,821
    #13 Rifledriver, Jun 18, 2009
    The only thing I would be concerned about is making sure the oil pressure stays ok. Hoses seals etc are not going to care about 300.
    I dont think a 328 is going to generate that kind of heat anyway. It is a pretty understressed motor by modern standards.
  14. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    On the positive side, it would certainly boil out any water condensation that might be present -
  15. Rifledriver
    36,821
    And that is something that really is a problem in many of these cars. A TR will NEVER get to 200 on a cold day and I am talking California cold, like a 50 degree day. Some days on a freeway drive the needle doesn't even move.
  16. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,302
    Netherlands
    Steven
    thanks!
    btw the oil pressure gauge showed virtually no difference with the oiltemp at 250 compared to normal driving. Stayed firm just before the 6Bar stripe. This to say with high reving. The oilpressure seemed a bit (half a stripe lower than normal) lower at idle but according to common believes that seems no issue either.
    Next time tracking will be with less wories!
  17. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,778
    Atlanta
    John!
    There is a video on youtube of a Gt4 being drive quite hard for quite a while on some track (wish I could recall which) and I saw the oil temp went up a bit but never past the 230. Good modern oils are just sort of "turning on" by that temp anyway
  18. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    I have a friend who is into rather extended (to put it mildly) change intervals. He drains his oil & bakes it in a a big roasting pan in a spare oven at 275F for a couple hours & re-runs it. Not saying I agree with his philosophy, but his car runs just fine after many years of this.
  19. Rifledriver
    36,821
    Good cooling.
  20. vincent355
    vincent355 F1 Veteran
    6,498
    Wine Country
    Vincent
    Don't tell PeterS about this.
  21. Llenroc
    Llenroc F1 Veteran
    5,441
    Colorado
    Vern
    What??..... I can't even think of a response to that.:) What is his philosophy behind doing this?
  22. Rifledriver
    36,821
    Probably a diesel and it runs on old french fry oil.
  23. David_S
    11,260
    Mountains of WNC...
    David S.
    He drives an old Lincoln whale of some sort. He figures since his car doesn't often get any long drives he can boil off any condensation and/or gas dilution this way. Me? I'd bet that his engine internals are so well "protected" by sludge by this point that a change with fresh (detergent laden) oil would probably be a bad idea :)
  24. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    One should always drive your car long and hard enough on each drive to get the oil temp up to 110c/212f for a few minutes in order to boil off the water that creeps into the oil via condensation.
  25. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    LOL
