Max wheel width on the rear | FerrariChat
Discussion in '348/355' started by Samy, Feb 20, 2007.
  1. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Hi,
    does anyone know what is the maximum wheelsize on the rear i can fit without modifications to the fender?
  2. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    some guys run 295 with 11mm spacers with no trouble with stock rims 315's with after market rim don't think you can run spacers there are pics to back up information on this site so check 315's were a sliver f355 with bbs rims it was SICK.
  3. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    315's!! Huuuuuuge! :D:D
    I remember seeing that somewhere! :):)
  4. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Where can i find this 355 with the 315 rims? Did he already had problems with them? Because i want atleast 305-315. Better something arround 325-345mm.
  5. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Wow! 325-345mm would be nuts!! I think I have the pic somewhere, I will try and find it for ya. :):)
  6. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I must get the horses to the tarmac :)
  7. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    I think with 300hp on tap, 315 section rear tires would be way too much overkill.
    My 255 tires makes the car quite lively and feels connected. I can see extending it to say 355/360 spec but beyond this I amguessing you would lose sensitivity/balance. Also the wheel/tire combo would be heavier.
    I have experienced a Boxster with normal tires and one with the upgraded 911 tires which were about 30mm wider. The car felt better balanced front to rear with the normal tires. With the wider tires, there was more eventual grip but the sensitivity wasn't there.
  8. PAP 348
    Dec 10, 2005
    100,224
    Pap
    :D:D:D
    I have to go out mate, when I get back, I will try and find that pic for ya. :):)
  9. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    GO TO SEARCH PUNCH IN "WIDEST TIRES WILL FIT" IT SHOULD COME UP WAS JUST LOOKING AT IT. GRAET PICS
  10. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Has'nt chaa got some really wide rear tyres on his 355?
  11. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I have 295/35 with 15mm spacers..... No problem. I think my camber is stock specs.
  12. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Yeah chaa has the same 295/35-18 w/15mm spacers.
  13. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Another note:
    I was at a shop that had a 355 with stock tires. They looked sunken into the wheel well.
  14. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I got 650hp / 750nm on the crank and reduced the weight of the car down to ~1150kg. I need big wheels to get the car controlable. I'm no pro race driver wich drives every week on the track. With small wheels its just realy dangerous because the rear is very nervous and i maybe can't catch it sometime and wrack the car.
    At the moment i'm at 285/30-19" because my wheels are only 9,5"x19" but i found some other 12x19" wheels with a design i like and will change to them and can mount bigger tires.
    I found the thread with the silver 355 with 315mm tires i think i get a set of those and look if the traction is ok.
  15. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    You think you can get 12" wheels on a 355? What offset?
    Do you have a link to the thread w/the 315's?
  16. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    PUNCH IN WIDEST TIRES WILL FIT IN THE SEARCH .
  17. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    That picture shows nothing of the fit. I'd be cautious unless you plan on adjusting camber. I'd like to see other pictures of that fitment.
  18. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    SAMY you need to post some photos of your car love to see the also engine. only fair. ha ha
  19. PAP 348
    Dec 10, 2005
    100,224
    Pap
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
  20. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I must realign all of the suspension because i had the hole car in pieces. So the 355 has these wheels in and then it will fit also on mine. 285 fit with some space so 20mm more should be no problem.
    I will make pictures when its all done and nice.
  21. PAP 348
    Dec 10, 2005
    100,224
    Pap
    We will all be looking forward to it. ;););)
  22. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I hope that all is done in april.
  23. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I believe Cig (Mambo Italiano) mentioned that he had tires that size on his 360.
  24. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Some serious rubber. :):)
  25. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,019
    NJ
    CRAIG ANDERSON
    found old tread with f355 with big tires do search punch "355gt" good pics of gt f355 with big tires .
