Maximize Wheel & Tire | FerrariChat
Discussion in '348/355' started by Phil Altomare, Sep 19, 2007.
  1. Phil Altomare
    Phil Altomare Rookie
    Feb 29, 2004
    9
    Phila., PA
    Phil Altomare
    OK for all you Hard Core 348 guys... Anyone KNOW how wide of a rim the 348 can tolerate before serious interference occurs. I want to maximize rubber at all four corners for the track, and after some preliminary measurements it looks like I can stuff a set of 10.5 x 17's on the front and 12.5 x 17's on the rear without too much trouble (specifically, touching suspension components under heavy load). Tires would be 265/40 fronts and 335/35 rears ,and the rims would have stock offset although I will probably add a 9.5mm spacer on the rears. Any comments or wisdom?
  2. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Why would you need that much tire for a car that makes only 300hp?
  3. B Feelgood
    B Feelgood Rookie
    Oct 16, 2005
    35
    Pittsburgh, PA
    Brian
    Seems like that would be overkill... My 500+hp Viper has 335/35-17 rears but for a good reason!
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Very valid question. I see an increase in lap times on the horizon after such a mod.
  5. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Wide tires are not for straight line speed. 300 or 3,000 hp on the same car makes it corner the same.
    IMO, the estimated max wheel sizes are a bit too wide. But thumbs up for trying to put as much rubber on the road ass possible. Post pics with the final result.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
  7. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Isn't weight also an issue? I've got to believe tires and rims that big in 17" would weigh quite a bit more than the magnesium 355 wheels in 18" with 285s in the back, which would slow you down....
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Absolutely, it could be an issue. Regarding 300 vs. 3000 hp, as an example, it also can make a difference in the curves. Talented drivers/race car drivers use the throttle to steer also, not just the steering wheel. If you don't have enough power for the size tires you can't steer using the throttle or at least not as well as would be ideal.
  9. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I hope you get the widest tires possible and show us what it looks like. I think a 348 with 335's in the rear would be awesome!!!!
    BT
  10. cscott67
    cscott67 Formula Junior
    May 13, 2007
    418
    Milwaukee
    Scott
    It would be fairly easy to do in a custom made 17inch wheel and still be light. (as light as the 18inch challenge wheels) The rear rim would have to be10.5-11inches as I recall. (11 would be better as the sidewalls are very stiff and hard to get that big of a tire on a rim any smaller) The fronts would be fine at 245, not sure any bigger would make any difference. Good luck, Scott
  11. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    Not only the increased weight, but mechanical resistance as well. You will not be as fast. Go with 18 355/355C rims with 275 or 285 on the rears. Go with better tires (auto cross or DOT race tire) for better grip. Michelin PS2's are 5lbs. per tire lighter than Goodyears according to Tire Rack specs.
    Lighten up for better performance. Don't make it heavier.
