Mechanical & electrical fuel pump rebuild? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 330gts, Mar 10, 2025.
  1. 330gts
    330gts Rookie
    Sep 11, 2009
    20
    Florida
    I know this may have been discussed on older threads.
    Looking for current advice and recommendations for best replacement parts kits for both the engine driven mechanical and electric Fispa fuel pumps.
    Unfortunately, it appears my 330 GTS may need both.
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,353
    Frederick, Maryland
    Brian Brown
    There is only one good kit for the Fispa mechanical fuel pump :https://www.ferrariparts.co.uk/part/ferrari/95180130?id=79445 I think that Rutlands sells the same kit. All of the other kits are crap, the check valves don't fit and don't work.
    I have yet to see a rebuild kit for the electric pump, all that is available is the diaphragm and gasket. The points block used to be available, but I have not seen them for sale, and there are 3d printed top covers that are sort of ok if you close one eye and squint. Typically the diaphragm and gasket are all that you need to repair the pump
    swift53 and Dustin Wetmore like this.
