Megafuse | FerrariChat
Megafuse
Discussion in '360/430' started by M430, Oct 17, 2021.
  1. M430
    M430 Karting
    Apr 12, 2012
    116
    tampa, florida
    marvin
    While checking for ground contacts, I accidentally shorted my battery with jumpers and may have blown the mega fuse behind the battery. Having a problem removing the cap to get to the fuse. Does it pry? Appreciate any help. Tks
  2. Qavion
    Qavion F1 World Champ
    13,885
    Ian Riddell
  3. Qavion
    13,885
    Ian Riddell
    The megafuse goes directly to the battery bus bar behind the left hand seat. If you can't get the mega-fuse cover off, you could remove the panel behind the driver and check the volts on the battery bus bar.
    Look for the big red wires.
  4. M430
    M430 Karting
    Apr 12, 2012
    116
    tampa, florida
    marvin
    Thanks, that was helpful. I removed the mega fuse and sent power directly to the battery bus bar and had 12 volts. Also have 12 volts with the mega fuse in place. Therefore, that is not the problem and still have no dash lights and engine will not turn over
    Qavion likes this.
  5. Qavion
    13,885
    Ian Riddell
    Do you have instrument power in general?
    The instruments (including the lighting) are powered by fuses in the forward luggage compartment (AF9 & AF15). These fuses get power from the battery (via maxi fuse 5) and the ignition switch respectively. Also, for dash night lighting specifically, an earth is required from the steering column light switch. Once the instrument cluster receives an earth, the general power going to the instrument cluster powers the night lighting. When you turn on the lights, do you get the sidelights on symbol on your dash?
    The mega fuse is not really involved unless you're talking about some serious power issues (e.g. fuse AF15 is powered by the ignition switch which is powered by fuses behind the seats (which are powered by the mega fuse). Does anything happen when you turn the ignition key on? If not, check fuse PDF18 behind the right hand seat or maxi fuse PSF19 behind the left hand seat for live battery power.
    The no start problem could be anything at this point. Let's see if we can sort out your lighting problem first. It may or may not be related.
  6. Qavion
    13,885
    Ian Riddell
    Correction. AF9 gets power from maxi fuse 4. There is a confusing numbering system on the contacts in the wiring diagram.
    This wiring diagram may help with diagnosis of the lighting problem:
    https://www.dropbox.com/t/u4uAQixCom4ZsKjX
    It's a work-in-progress.
    Link expires in 6 days.
    The maxi fuse is in the middle on the right. The instrument panel is identified as E003. Let me know if you need connector locations.
  7. M430
    M430 Karting
    Apr 12, 2012
    116
    tampa, florida
    marvin
    AF 9 and AF 15 are good. Are you referring to the relays as maxi fuses? Also, when I reenergize the system, all dash lights and night lights come on, but only for about 5 seconds, then everything goes dead again. Starter does not turn over, only buzzes. door lights and trunk lights work at all times.
  8. Qavion
    13,885
    Ian Riddell
    No, I mean the larger fuses next the battery and also behind the left hand seat.
    It's strange. The symptoms seems to be pointing to a flat battery, but you've said the battery is showing 12 volts. By the way, do you have a trickle charger (tender) and have you removed it? On some cars, the official Ferrari battery charger inhibits starting when plugged in (to prevent you driving away with the charger plugged in).
    You may have a power supply problem in your instrument panel. It's a known problem.
    https://www.ferrarichat.com/forum/threads/wiring-diagram-instrument-panel-360.357681/#post-141247103
  9. M430
    M430 Karting
    Apr 12, 2012
    116
    tampa, florida
    marvin
    Ok, I will check the fuses behind the drivers seat. Also, I installed a new 34R battery about 10 days ago and made sure it was fully charged. Yes, I am aware of the dash supply problem,
    Qavion likes this.
  10. Qavion
    13,885
    Ian Riddell
    This probably means live battery power is reaching the doors. Your glovebox light, parking light switch and interior light is probably working, too.
    I would check for voltage on fuse AF15 in the luggage compartment with the ignition turned on. If not, work backwards towards the source:
    i.e. Check for live battery voltage on fuse PDF18. If no luck, check for live battery voltage at maxi fuse PSF29.
    I assume you have an Owners Handbook for your car.
