membership battery drain on 360 | FerrariChat
Discussion in 'Technical Q&A' started by zapper/dapper, Aug 25, 2018.
What could cause my battery to drain on my 360 overnight
  1. all
    0 vote(s)
    0.0%
  2. all
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. zapper/dapper
    zapper/dapper Karting
    Feb 26, 2004
    53
    my 360 battery drains overnight
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,641
    South East
    Jimmie
    Either you have a dead battery or a short somewhere - how old is your battery and/or do you keep it on a trickle charger ?
  3. hessank
    hessank Formula 3
    1,901
    Canada, Florida
    Fred
    Are your parking lights turned off (switch on centre console and not the one by the steering wheel)?
  4. mello
    mello F1 Veteran
    5,471
    CA Bay Area
    Steve
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Parasitic drain.
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,676
    As cars get older, the electrolytic capacitors on the various circuit boards degrade and begin to leak.
    When my F355 was new to me (2001) it would go 3 weeks and still turn over.
    Now (2018) the battery won't last a whole week.
  7. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,727
    Just East of Weird
    Bob
    Do you have an after market stereo.? They have been known to drain the battery.
    Or similar to above, a door micro switch has been found to short and cause a drain. There are several threads on this on the 360/430 forum
    Sent from my iPad using Tapatalk Pro
  8. Mitch Alsup
    Nov 4, 2003
    9,676
    I have had a relay installed so the radio only has power when the key is on.
  9. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    Unbolt your negative battery terminal and put a volt/ohmmeter between the terminal and the battery post. If you read 12.6 volts, then switch to current to see what the drain is. Anything more than ~ 100 mA will drain your battery.
    If you are > 100 mA, unplug all your fuses (drain should go to 0), plug them in one by one until you find the culprit. If is stays at > 100 mA with all fuses unplugged, then the drain is on a non-fused circuit (e.g. lights)
  10. zapper/dapper
    Feb 26, 2004
    53
    No.. oem radio
  11. zapper/dapper
    Feb 26, 2004
    53
    Thank you very much for your insightful response
    Thanx for the infor.. will check it out!
