Mercedes Battery Question | FerrariChat
Discussion in 'Other German' started by jeff, Dec 20, 2004.
  1. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    The battery in my MB is exactly 5 years old. As far as I know there is nothing wrong with the battery. Should I replace the battery just as a precautionary step? Is 5 years a long time for a battery to last?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    Cold is what kills a battery. Seeing as you live in Scottsdale this is not a problem at all for you. In your type of climate 10 years should be easy for a battery. Come to Canada at -40 Degrees C and then 5 years is still on the early side to change.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I'd estimate a 3 yr ave. for me depending on use. I've never just changed a battery as a precaution but it would save you the headache. Mine have usually died at the house so I've just had AAA pick it up or had it replaced right here. So, I've been lucky.........
    Usually my batteries die more from lack of use, not over use. The battery tenders have done a great job keeping them ready.
  4. rob
    rob F1 Rookie
    May 22, 2002
    4,287
    Vt
    It seems the batteries of today last a lot longer than they used to. I bought my toyota 7 years ago this month and it was used when I bought it and it still has the same battery in it. It as been below zero every morning here for almost the last week and it has started right up. I previously had thought that batteries only last four or five years.
