Mercedes W03 | Page 12 | FerrariChat
Mercedes W03
Discussion in 'F1' started by Ferraripilot, Feb 1, 2012.
  1. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    It's the low down force front wing that has peaked my curiosity...
  2. Isobel
    Isobel F1 World Champ
    Jun 30, 2007
    10,630
    On a Wave's Chicane
    Is, Izzy for Australians
    That is incorrect....but I'm not reaching for my Coach Kristin yet...;)
  3. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,642
    @ the wheel
    Andreas
    I really hate the covered cockpit. I was hoping that was still many years out.
    OTOH the new wheel tethers are impressive.
  4. tifosi12
    Oct 3, 2002
    49,642
    @ the wheel
    Andreas
    Actually it is correct: With the 1991 points system MS would have beaten Nico by 3 points.
    Obviously there are dozens of different point systems over the years yielding different results, but the one before last did the trick.
  5. Isobel
    Jun 30, 2007
    10,630
    On a Wave's Chicane
    That isn't the part which is incorrect....;)
  6. tifosi12
    Oct 3, 2002
    49,642
    @ the wheel
    Andreas
    Oh, squeeze me. I didn't go that deep into deciphering the original message. I believe you however.
  7. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,855
    Atlanta
    John!
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    Every team in F1 is ALWAYS up to something.
    It is the nature of the beast.
  9. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    That's definitely true, but every year almost without fail there is one team doing some 'it' thing that actually works and everyone copies. EBD, DDD, bendy wings, j-damper, blah blah blah.
  10. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
  11. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    628
    Eden Prairie, MN
    Matt
    Very interesting article...that helps explain why it would be so difficult to copy if they're really routing from the back wing all the way up front. Do they (Mercedes) still have the slot in the nose area similar to the Red Bull? I wonder if that helps add velocity to the air moving through from the rear to help stall at a lower overall speed? Great catch and thanks for posting! I'm actually thinking of keeping my old rear out of bed for the PF1 live stream tomorrow. Usually with the Far East races my DVR does the dirty work (altough this isn't without folly as rain has made me an unhappy viewer in Malaysia)
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #287 Fast_ian, Mar 14, 2012
    Very interesting indeed - *If* that's what they've done, and it works as advertised I'm really impressed. However, I'm still not convinced for a couple of reasons;
    - I don't see how the air "in" the holes when DRS is open is going to be at a lower pressure than the air whizzing by it - As we know, high speed air = low pressure air - I'd guess it would be more likely to be *sucking* air out of the holes! [Also possible, and a little more likely?]
    - The plumbing to move the air all the way thru the car has gotta be a nightmare - I guess I'm just not "feeling" it.
    But, I was wrong once! ;)
    Cheers,
    Ian
    PS - Hopefully Scarbs doesn't mind me reposting his drawings for illustrative/newsworthy purposes (?)
  13. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    I know him, and he is cool with it so long as his name is mentioned, which it obviously is in most of his photos!
    Anyway, there is some theory out there that the front wing hole in the nosecone is constantly flowing to the rear wing holes which are covered by the DRS flap, and when DRS is activated, a switch junction decides whether to stall the front wing based on DRS being activated OR if the front nose hole reaches a certain pressure. This means the front f-duct could work two ways; with DRS as a secondary function (legal), and passively as the front hole reaches a certain pressure. Regardless, this could mean the Merc is *the* qualifier this year.
  14. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Very cool.
    The more I think :)eek:) on this, the more I think he's got it backwards. The original f-ducts worked by feeding additional air to the rear wing, right? That's exactly what opening this hole is gonna do - Air is being "sucked" (by the low pressure air passing by) out in the vicinity of the rear wing and voila, a legal f-duct.......
    I'm not sure about (anything!) a switch being legal - Even passive Charlie isn't gonna like that. But, when the DRS is closed there's obviously no flow front to rear - Open it, and it's gonna suck like a hoover and who knows what then happens at the front.
    Cheers,
    Ian
  15. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Gills reappear on the Benz sidepods...*sigh*
  16. Mitch Alsup
    Nov 4, 2003
    9,732
    The Airforce did experiments in the mid-1960s with slots milled in the wings of experimental aircraft. When air was blown through the slots drag decreased without losing lift.
  17. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    I actually heard that these were perhaps intentional. The gills are pointed towards the exhaust and the exhaust essentially supercharges the additional air coming from the gills thus aiding downforce. I've also heard those sidepods are specific for Malaysia only. Not sure. We'll see right.
  18. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Good.
    There's little enough innovation left in F1.
  19. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    Mitch, thank you for this. Huge thanks actually. I spent a good amount of time on the phone with a friend of mine who is an engineer with Boeing talking about laminar flow and slots near the trailing edge. He seemed to believe flow would be unaffected if the design were built around knowing they were there, but the bottom of the wing needed to compensate in some ways. Great case study example though Mitch.
  20. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    "No moving parts, completely passive, nothing" , per Whiting.
    Amazing, how did Mercedes do this. I knew Bob Bell hid himself away in Brackley for good reason. I'm going to go out on a limb here and say a Merc might just make pole this weekend.
  21. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
  22. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    #298 Ferraripilot, Mar 15, 2012
    And so long as it's a secondary device as well I believe
  23. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    The genie is out of the box.
    Now we see how effective it is and how long it takes the rest of the field to adapt.
    Got to hand it to Ross.
    Again;)
  24. Ferraripilot
    May 10, 2006
    17,855
    Atlanta
    John!
    I was wondering this same thing. If there is indeed ducting from the front to back, I know this is not going to be an easy adaptation as any modification to the crash structure requires crash testing. If we see teams adapting to this rather quickly than it might be safe to say that there is no ducting from front to back. Then again if the system is as Whiting says, "completely passive" and is linked to the rear DRS, how on earth would they not be linked. Bell and Brawn really got one over on the field with this one......again.
    Rumors say this further stalling of the front wing in combination with DRS adds another .500 during qualifying. Fast. Especially at the power circuits. Australia sees a top end of around 310kph so we'll see how this does.
