Mercedes W03 | Page 16 | FerrariChat
Mercedes W03
Discussion in 'F1' started by Ferraripilot, Feb 1, 2012.
  1. DF1
    DF1 Three Time F1 World Champ
    +1 and top speed is everything here almost like Monza it seems. Those low on top speed will suffer. Ferrari is and so will Mercedes as the race wears on potentially. Mclaren look tops so far. More of that and then there will be a team dominating!
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,847
    Atlanta
    John!
    #377 Ferraripilot, Mar 23, 2012
  3. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    627
    Eden Prairie, MN
    Matt
    Not sure how you get the unbelieveable pics of the Merc, but I love it! This has quickly become my favorite source of F1 discussion!
  4. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Pirelli downplays Merc tire issues;
    I think he has a point.......
    Cheers,
    Ian
    http://www.autosport.com/news/report.php/id/98298
    PS - Very interesting pic above..... I'd love to to see the pressure readings in various places under the different conditions on this thing. If it is indeed feeding forward (and I'm still not convinced it's not going the other way!) the rear hole is gonna have to be at a *much* higher pressure than the front to force thru all that piping. OTOH, I guess the underside of the front wing is about as low (pressure wise) as it gets......
  5. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    I think we can safely say the Merc has certainly improved.
  6. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    #381 Ferraripilot, Mar 23, 2012
    I believe this is how it works, and it supports my theory that the front wing duct remains in semi-constant operation:
    DRS IS NOT ACTIVATED - Air enters through the nose hole, pressure builds up in the nose cone and air is blown out through the slots on the underside of the wing stalling the front wing above a certain pressure.
    DRS IS ACTIVATED - The two ducts in the nose cone now release the pressure in the nose cone and allow the air to flow through the ducting and exit out the rear wing DRS-duct. The slots on the underside of the wing are not blown sufficiently to keep the airflow attached, and the wing stalls, reducing drag. This method essentially uses the DRS-duct as a release valve for the air in the nose cone.
  7. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    I'm not getting it.
    Why stall the front wing when DRS is inactive?
    Isn't that when you want downforce and grip?
  8. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    Stall the front wing once a certain pressure is realized. So, set up the wing so it's not affected by this tangential flow inside the nose until let's say above 120mph. This would also allow them to use a lower front static ride height due to less high speed tea tray deflection (due to less downforce from stalled front wing).
  9. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    A delicate balance to finesse. But more has been done for smaller benefit so who knows.
  10. Kyoso_Joey
    Kyoso_Joey Formula Junior
    Nov 7, 2010
    275
    Scottsdale
    Joey
    I love how everyone was crying about it and talking about protesting. Its a great design that other constructors didn't think of and is a great example of thinking outside the box.
  11. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    ha! agreed, they simply wish they'd thought of it first :)
  12. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    Make note, W03 has by far the softest front end on the grid which is evident by the massive front end roll displayed especially on quick turns. Still trying to figure out why this is.......
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    A soft suspension gives more mechanical grip, this is how Merc is dealing with the rear tire degredation issues found in Australia.
    As long as the roll incurred does not 'roll' the tires off their 'proper' dynamic camber, little harm is incurred.
  14. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    Given the tiny differences between soft and hard on a modern F1 car I don't see it as a concern.
  15. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    #390 Ferraripilot, Mar 25, 2012
  16. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    What is the light covered plate?
    Is it temporary, just there to disguise?
  17. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    I hear W03 is going to undergo a Mclaren-type exhaust treatment soon. I've also finally heard some reasonable conjecture regarding the current EBD. Whiting is quoted saying the Mclaren and Red Bull exhaust arrangements are currently worth about 20% of what the original EBD was worth and that 2013 exhaust regulations will further crack down on this EBD blowing nonsense. Furthermore, the original EBD was worth right around 25% of total rear downforce meaning this year's version is perhaps worth 5%. Still no one knows how it compares to the W03 or Lotus E20 current exhaust arrangement, but apparently Costa sees value in the Mclaren arrangement as he has been quoted as saying such a exhaust arrangement being declared 'legal' is a 'gift'. I would definitely say that Costa's words imply they will implement such a thing shortly.
  18. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,612
    @ the wheel
    Andreas
  19. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
  20. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
  21. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    Nope.
    I pondered last night the problem with W03, as it doesn't have any fundamental issues like W02 and W01 had, or even like F2012 still has (yet Ferrari have done a magnificent job working around them). The problem with W03 is it is a very fickle machine. Everything has to line up just right for it to be truly quick, and we've only seen that happen at the 100% level a couple times this year, and that was of course Monaco and China.
  22. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    #397 Ferraripilot, Jul 31, 2012
    Compared to W02 and W01, W03 even compared to most cars on the field except Mclaren and Lotus, has exceptional attention to detail. I'm really not worried about this team, especially compared to how poor F2012 came out at the beginning of the season. Ferrari have poured too many resources into that car and have no chance at a WCC, just my opinion.
    Pic shows old wing (below) vs new wing. Note they have not been running the primary cascade as I believe the wing is running more rake than it was earlier in the season when we did see it with the cascade. I'm guessing the rear is unbalanced with it in place.
  23. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    Interesting but since they run different configurations for high and low downforce tracks are you sure that the changes aren't track specific modifications?
  24. Ferraripilot
    May 10, 2006
    17,847
    Atlanta
    John!
    I believe they partially are. Each team must weigh if they want heavy downforce or less drag and figure a balance of the two depending on their chassis capabilities. In most cases they want more downforce and it's usually at the rear.
  25. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    As a rule all teams have rather different high and low downforce setups and the front ends differ markedly.
