360 - Mesh oil filter | FerrariChat
360 Mesh oil filter
Discussion in '360/430' started by collegeboy, Apr 7, 2025.
  1. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    When changing the oil, are you supposed to remove the mesh oil filter every time as well? I have the FSM and couldn't find the answer. Changing my engine oil and transmission oil after 1,500 miles since my manual conversion (6 months) since I want to get under the car anyways to triple check everything. Also, do you replace the o-rings with new each time? Just wanted to ask.
    Thanks!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,932
    Central NJ
    Dominick
    I am sure if you look at the WSM it will say it is part of the oil change procedure but IIMO i would baseline it once ( meaning clean it / replace it once if you are not original owner) and then clean/replace it every 3rd ( in your case based on the miles you put on - approx 7500 - 10000 k miles) ..this goes for both screen filters - trans and engine
  3. collegeboy
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    Perfect. That's kind of what I was thinking. Not needed every single time and I just replaced them both with new during the manual swap.
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,112
    Josh @jtcarprojects
    If you remove the screen common sense would be to change the O rings.
    flash32 likes this.
  5. collegeboy
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    Absolutely. I don’t have any here. One reason I was asking. I’ll deal with the screens next fluid change. Main thing is me just getting under the car now anyways and switching to Redline.
  6. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,112
    Josh @jtcarprojects
    I'm sure you will figure it out but when you ask about changing a O rings makes me wonder.
