Metal or Fiberglass 308 front valance ? | FerrariChat
Discussion in '308/328' started by thecarreaper, Jul 19, 2009.
  1. thecarreaper
    thecarreaper F1 World Champ
    18,067
    Savannah
    #1 thecarreaper, Jul 19, 2009
    I think BigTex mentioned one time that one of the three early 308 carb cars in his possession has a metal front valance. all of the 308s i have owned or seen up close have had fiberglass front valances. deep or shallow.
    MY QV also has a factory metal shallow front valance, and i am in the process of adding the deep euro valance to the car. ( waiting on the paint shop)
    my thread on the process can be found here:
    http://www.ferrarichat.com/forum/showthread.php?t=249758
    can any of you chime in on whether or not the 1979-1985 308s you have had contact with had glass or sheetmetal valances?
    did it vary by year, or perhaps country of final delivery?
    now that i have posted this, i am going to look for my assembly number (54) on the metal valance and verify it is indeed original to the car.
    were the factory deep valances made out of metal at any time?
    it occurred to a buddy of mine that you could modify a metal shallow valance to look like a metal deep "euro" style very easily.
    thoughts?
  2. myfazzman1
    myfazzman1 Formula Junior
    657
    down under,australia
    peter
    G'day mate
    Been following this with interest! My 1984 308 Qv GTS(Australian Delivery) has a metal "short" valance.(We call em Spoilers)
    I have seen both metal and Fibreglass European front valances used on 308's throughout the years and these are cars which I know are factory original.
    I would think that like a lot of things with Ferrari at the time,it was a case of " use whatever was at hand and available Luigi" at the time!
    When fitting the deeper European front spoiler are there any issues with the Fibreglass front wheel arch liners being too short?
    Cheers
    Pete
  3. thecarreaper
    18,067
    Savannah
    hi Pete, i will look at the fit of the fender liners when i do the final fit. as far as i could tell they were fine, as i did not need to remove them to get the bolts out with the grill and bumper removed. i removed them afterwards to look around in there.
    the QV i have is the first metal valance i have seen. it is indeed original to the car, and is made up of several welded parts. everything on my car was undercoated at some time in the past, so i cannot find any marking on the underside without disturbing the coating.
  4. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    My '82 GTSi has metal, short. RHD Euro spec.
    AFAIK all long ones are finberglass. I was under the impression that all short ones after the vetroresina cars were metal, but that is then wrong?
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    My '77 is shallow, and fiberglass. I know because the number of times I have repaired it. :(
  6. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    When I owned my (US) '78 308 it had a glass short valance. The new owner ordered another form the UK with the intent of changing to "Euro" a deep chin. He received a metal short valance and was told that it was an option in Europe at the time hence the mix-up I guess.
    The nice thing about the short valance is excellent clearance and never having to worry about scraping.
  7. Crazyhorse
    Crazyhorse Formula Junior
    Jul 23, 2007
    450
    Mooresville,Nc (Race
    Bill Long
    My 1982 US car is short and metal.
  8. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    Correct, all long (or "deep") ones are fibreglass. And I have had both FG and steel short frontvalances. Don't know if the Vetroresina (car)production stop is also cutoff date for the FG fronts, since they continued to produce the fibreglass lower rearend on Euro cars.....
  9. ragtop1
    ragtop1 F1 Veteran
    5,241
    Ontario
    Larry Warren
    my '79 GTS is glass
    my '82 GTSi is metal
  10. BigTex
    79,380
    Houston, Texas
    Bubba
    My 'newest' one is metal, Micheal....22641, 1977....it's three pieces, for one thing and does away with the fitment problems of the one piece 'glass.......
    As always, I'll take all your 'cast off' parts, to support your efforts if unwanted......
    I say the prevelance of the 'glass ones is due to the ease with which they are damaged...
    The front "nerf bar" installed on my #22127 is one of the better ideas I've seen.....
  11. BigTex
    79,380
    Houston, Texas
    Bubba
    I'd say "no' as my two 1976 and 1977 steel cars #20405 and #22127 have fibreglass valences.....all three of mine are shallow versions.
    And still see pretty frequent damage! LOL!
  12. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    My 81 has a short metal one and at outer corners I have to attach skid plates as it is worn through, which is strange as the quater mile of gravel road to the hwy is high in the center but no damage in that area.
    Stephen
  13. BigTex
    79,380
    Houston, Texas
    Bubba
    The outer corners scrape as you turn up inclines...like, say....a driveway!!!!
  14. stephenofkanza
    Mar 5, 2005
    542
    Kansas
    I have only drove up a drive way twice and that would 2 times each side, they there when I bought her in Jan 05 and the PO did have an incline driveway.
    Stephen
  15. flaviaman
    flaviaman Formula Junior
    Jul 26, 2005
    318
    Vernonia, OR
    Gregg
    As I recall the metal valance (shallow) replaced the fiberglass piece in late 1980 or early 1981 production, I believe the 308i parts book lists the production split, Ferrari just supplied the metal valance as a SS part from that point forward.
    All "deep" valances were fiberglass. Someone asked if the stone shields inside the wheel wells are different on the deep valances, they are.
    The deep valances look great, but as noted previously they are a pain in terms of clearance with curbs, driveways, ramps etc.
  16. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    #16 speedy, Jul 20, 2009
    You got that right.....
    My '83 Euro has a glass valance...deep style
  17. Jdubbya
    Jdubbya The $10 Trillion Man
    43,189
    PNW
    Mine is a short glass one on a '78 GTS
  18. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    my 84 had a long fiberglass one, I swapped it for a short fiberglass one.
  19. thecarreaper
    18,067
    Savannah
    bingo! excellent post. i looked in my parts manual and chapter / page TAV 152 # 19 shows as " Spoyler normale 60395902 and Spoyler maggiorato 60280500 ". i will make new fender inserts at work if i do need to change them. i work on biz jets and have access to the scrap aluminum in the recycle bins.
    and thank you all for the replies!
  20. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    'No' to what exactly Bubba? My point is, that short ones can be either FG or steel, the deep ones are always FG.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    Yeh, I have a steel one sitting on the shelf here so I know they're real....anybody need one BTW?
  22. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    What is this nerf bar of which you speak?
    Thanks,
    Doug
  23. eracer
    eracer Karting
    May 29, 2009
    141
    Michigan
    Eric W.
    My euro '82 GTSi has a fiberglass deep spoiler.
    The trick to avoiding constant repairs is to take steep driveways at an angle (very slowly).
  24. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    #24 Neonzapper, Jul 20, 2009
  25. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Mine had a few scrapes underneath but nothing cosmetic to repair. I always thought of my 308 as the 4 x 4 of Ferrrais. I don't recall scraping anything when I owned it. I went over lots of speed bumps and transitions
