metallic paint question | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ross, Mar 18, 2014.
  1. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    38,110
    houston/geneva
    Ross
    just to show you how dumb i am when it comes to this sort of thing, can somebody explain how metallic paint works.
    i realize that the paint must have tiny bits of shiny metal in it, but then how do these fit through the spray nozzle? and if it is that larger flake stuff, then the question is the same but more puzzling.
    laugh at will, but thanks for answers.
  2. JCR
    JCR F1 World Champ
    10,992
    H-Town, Tejas
    The flakes are mixed in the sprayed on color coat and then covered by a clear coat. And yes they go through the nozzle. Historically the flake used in European cars has generally been smaller/finer than American cars. There have been exceptions. The 2002 Silver Arrow Edition MB SL500/600 used the more blingy large American style flake in the metallic silver which was over a $1k option for the paint alone.
    And then there is Metalflake.
    https://www.google.com/search?q=metalflake&biw=1226&bih=627&tbm=isch&tbo=u&source=univ&sa=X&ei=BKYoU5nlCsiV2QX_r4GwDQ&ved=0CDUQsAQ
  3. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    Normal metallics are small enough to fit through a standard spray gun nozzle. It does come in several sizes or coarseness. It is mixed with the color and sprayed in a similar manner to solid colors. However, there are spray techniques utilized to be sure the metallics don’t look mottled. Metallic paint comes in both base/clear systems and single stage (no clear) systems. A lot of what looks like metallic now is pearl. Pearls are added to the color coat just like metallic in most cases. However some pearls must be added to an intermediate coat over a regular basecoat to achieve the desired effect. This is known as a tri-coat. Pearls give more color and bling than metallics. Xirallics are an even newer additive that is seen on new cars. Those really sparkly metallics on the new cars is Xirallic. The only factory that produced xirallics was damaged in the Japanese Tsunami a couple years ago. So there was a shortage for a few months. Metal flake is larger flake that is put in an intermediate coat or applied in the clear coat. Metal flake may require a larger nozzle or even a flake gun. Metal flake is for bass boats.
    Larry
  4. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    It would also be worth mentioning that there are also different colors of metallic flake to give different hues when a car is under direct sunlight.
  5. Pass
    Pass F1 World Champ
    13,163
    Salida Colorado
    Mark Passarelli
    Most but not all are ground up mylar... comes in three different sizes. For the most "European" style of paintwork I always specify all my metallic paint formulas substitute all medium metallic with fine when mixing.. It gives a paintjob the "Glow" rather than the "sparkle" and more closely resembles the 1950's and 60's German paints I use.
